mobile broadband contract (data sim) used in UK, not working in Europe
gina_22
I tried to find out how to activate roaming before leaving the UK but the only instructions are for phones, there's nothing about data-only sims for use with a 4G mobile router for tablets/laptops.
I was using it fine in the UK but in France I got "NO SERVICE" then "Roaming! Please access Web UI to reconnect" and in Spain only "NO SERVICE".
In France I used the hotel wifi to get online but again failed to find anything about connecting mobile broadband roaming on the EE page. If "Web UI" refers to the router's, I've forgotten the password and don't know how to reset it, if such a possibility exists. Please advise how I can use my data in Europe.
James_B
EE Community Manager
Hi @gina_22,
The error message you shared indicates that you need to login to your router to reconnect to the internet.
Are you back in the UK now?
To access your mobile WiFi admin console, you'll need to be connected to your mobile broadband router, rather than your home router.
22 REPLIES 22
Leanne_T
Hi @gina_22
Thanks for coming here 🙂
If you have a pay monthly account can you, log into your My EE account online go to Menu > Account Settings > Parental and Data Controls > Enable Roaming and also Make calls abroad from the UK > can you activate both settings?
Thanks for the suggestion, Leanne-T, but I have just gone to Parental and Data Controls and see that both Enable Roaming and Make calls abroad from the UK are already activated, but I'm still getting "No Service" and "Roaming! Access Web UI to reconnect" even though the router shows a 4G connection.
James_B
Hi @gina_22,
Which router are you using?
gina_22
Huawei E5776s-32
James_B
Hi @gina_22,
To access the web console, please visit http://192.168.1.1 when connect to your router via WiFi.
The username and password should both be admin.
Does that allow you to reconnect?
Hi, James,
That URL takes me to the home router management page, not my mobile one. I assume that that's because I have wifi from the home router (otherwise I wouldn't be able to get online, because I can't get a connection through my mobile router, which is the problem I'm asking about). However, I imagine that what you're saying is that the problem lies in the router itself. Is that correct?
Gina
James_B
Hi @gina_22,
gina_22
Hi, James,
In that case it'll have to wait until I'm back in the UK, or, more practical for my current situation, I'll have to get a new mobile broadband router here and see if that works.
Thanks.
Gina
James_B
Hi @gina_22,
You should still be able to access your router's admin console outside of the UK. Just make sure you're connected to your mobile router, rather than another WiFi source.
