Wifi calling on new broadband doesnt work
Lizlevs29
I have just upgraded my broadband & now I cant seem to have a conversation with anybody on the phone using WiFi calling. They just keep cutting out
6 REPLIES 6
Maestro
Maestro
@Lizlevs29 What was involved in the upgrade and what has changed from the original, WiFi calling works well on the EE Smart Hub 6+ version hub wise, cutting out try to stay near the EE Hub when testing it.
baron75mk3
Ive had a lot of issues with WIFI calling on all sorts of providers & hubs , its very hit & miss sometimes its great other times its terrible , i have experienced the issues the OP mentions but on pretty much every provider & setup i have had , it goes through google so weather that has a bearing on it or not i cant say , its very much an emergency function for me these days.
@baron75mk3 : Where or how does it go thro' Google?
Only if you use google voice calls & google Fi Wireless  , but regardless when first enabled on android you have to accept a google agreement of some kind (possibly if you are in the US where they are available ?)  hence "goes through google" ..... in some way ? , i never specified how & does it really matter ? it has no bearing on my reply whatsoever i offered no fix or even tried just a ..Statement  , seems to me there are 1 or 2  bored people here with  nothing better to do than to nit pick others statements to pieces in order to TRY prove how smart they are.
@baron75mk3 : Hence your statement needed some qualification for such rare overseas exceptions.
If it has no bearing then why say it? You said it in public; so it matters!
Thanks, I'm smart ...ing!
Makes no difference whatsoever ....As i offered no fixes or even insight into the issue i simply was stating not to be to quick to blame EE for the issue as i have encountered the same problems as the OP on multiple providers & equipment & also
"weather that has a bearing on it or not i cant say"............witch it may or may not as i said.......I dont know
& that because of the SAME issues as the OP i just use it as a backup solution if the network is down or something.
Also i never said you were smart i said "TRY prove how smart they are" reading & understanding is not your strong point , if it were......this conversation wouldn't be happening , also you decided to come here & decide it was your job to go around correcting others & TRYING make others look bad, i never asked you to tag me did i ?
Do yourself a favor go pick on someone else.....you are nowhere near as smart as you think you are
so next time DONT tag me as if you do? ......ill just ignore you
