07-05-2026 10:36 AM - edited 07-05-2026 10:40 AM
I am having an odd issue with the FortiClient VPN that my work uses. I have used it in other jobs before, but since I am back on EE and BT, it is constantly disconnecting from the Europe server. Is this an issue specifically with BT consumer connections that could be causing these disconnections? I am using V 7.4.7.2003 - Mature if that matters, oddly the same vpn works fine from office but we are hybrid three days at home and it does work but just disconnects after x period
Just to add I am on FTTP 900Mb Full Fibre to the premis
08-05-2026 04:19 PM
Hi @novagaming
Thanks for coming to our community.
If it's just the VPN connection that is causing you an issue and your broadband is otherwise working ok, it may be difficult for our technical team to investigate.
We have some knowledgeable users on our forum who may be able to offer some advice. If not, it may be worth giving our team a call so they can check everything is working as it should be on our side.
Lesley
08-05-2026 04:19 PM
Hi @novagaming
Lesley
07-10-2026 10:02 PM
I switched to EE this week and my work laptop will not connect to the internet, I think our Forticlient software is the problem. All other devices, other laptops, phones and TVs, even the printer, are connected and working properly, though Forticlient does not run on any of them.
Work IT made a setting change, don't ask me what, and said this would 99% solve the issue but alas, when I returned home, no connection at all. Even when using a ethernet cable there's no connection.
How can this be fixed?
If it can't, can I cancel my contract?
Grateful for any guidance on this.
07-10-2026 10:18 PM
@Maccon44 You have 14 days from when your EE connection went live to cancel and move.
