24-05-2023 10:02 AM
I have a 4GEE Router with Mobile Broadband. This page (https://ee.co.uk/help/help-new/phones-and-devices/ee/4gee-home-router#settings-and-updates/enable-or...) suggests that I should be eable to enable/disable the firewall in the Security section of the router configuration page, but I don't seem to have the option to do so (I've attached an image showing my options) - is there a reason I can't see this? Does the 4GEE Router + Mobile Broadband come with a built in Firewall?
05-06-2023 11:40 AM
Hi there @Leanne_T ,
It's been a couple of weeks now so just wanted to check if there has been any progress? Did the device speclialists get back to you? 🙂
05-06-2023 11:51 AM
05-06-2023 11:52 AM
Awesome, that's great - thank you so much for looking into that for me 🙂
05-06-2023 11:53 AM
No problem, sorry for the delay @jc3618
Leanne 🙂
30-07-2023 05:21 PM - edited 30-07-2023 05:23 PM
I have the same device and I would like to know if there is anyway to disable the firewall, I have to use a corporate VPN when connected to the internet and this VPN is clashing with the firewall.
thanks
31-07-2023 02:45 PM
This is on as default and unable to be changed.
If you are unable to access the VPN, please contact our tech gurus to get this looked into.
