08-10-2026 09:03 PM
08-10-2026 09:17 PM
If it is a neighbourhood issue, you could consult Check service in your area to see if any faults are being attended to in your local area. You may also Report a Problem there.
No one will contact you from this user discussion group other than thro' the medium of these forums by posts such as this. Anyway we haven't the faintest idea who you are. You need to phone CS.
08-10-2026 09:17 PM - edited 08-10-2026 09:28 PM
@Peter-L Have a look at what your package from EE Supports. Standard is the latest name to get the Keep Connected and the older was called the All Rounder.... EE are the ones that possibly can explain if OR have advised what is required to be done. Fix takes as long as it takes. You need to be calling EE CS, the Forum is public so do not expect anyone from EE to be calling you from this posting.
Standard and Fibre Broadband Plans Terms and Conditions | EE
