Re: Issue UPnP Not Successful XBox/PS4 Using New EE Smart Hub plus
Battlecub
Hi I have been having the exact same issue, never had a problem with BT but switched to new EE broadband and can't connect the Xbox via ethernet cable and the app doesn't work so can't use the Gaming Mode, which was one of the main reasons we switched over
J D Bailey-Brown
36 REPLIES 36
Profile closed
Not applicable
that why i swich was cos game mode and we move back Dec 2023 still cant use and smart hub plus and smart hub2 run same boot OS
Daniel-S
Former EE Employee
Hi @Battlecub,
I've created a new thread for you as you're mentioning issues that @Profile closed doesn't seem to have.
What Xbox are you using exactly? Does the connection work ok through WiFi? What specific error message are you getting and does this stop you from gaming at all?
Thank you
Daniel-S
Thank you.
I am using an Xbox Series X, so when I connect via Ethernet cable it will work but it has
Wired
IPv4 & IPv6
NAT Type: Moderate
UPnP not successful
xbox.com/xboxone/UPnP
We haven't been able to use the WiFi Controls either so can't activate the Game Mode or manage our settings
I have checked the hub manager and the UPnP setting is on and DMZ is off
J D Bailey-Brown
Profile closed
Not applicable
I am having same issue
"I am using an Xbox One S, so when I connect via Ethernet cable it will work but it has following issue
From
We haven't been able to use the WiFi Controls either so can't activate the Game Mode or manage our settings since Dec 2023
JamesS84
I am having exactly the same problem. I setup EE hub since the BT merge and never had a problem with my Series X. Now every time I switch the console on dashboard says "connect to internet" I also have the issue where I have to constantly test NAT type so it is open rather than the default Moderate. Surely an update could fix this? Or has anybody found a solution?
Profile closed
Not applicable
you after port forwarding
These ports must be open to connect to the Xbox network:
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
  • Port 500 (UDP)
  • Port 3544 (UDP)
  • Port 4500 (UDP)
@Profile closed : In which direction?
I mean I have the exact same issue as your screenshot Alex.
IPv4 &IPv6
NAT type Moderate
UPnP not successful
This is every time I turn my console on. Going to ring them on my break see if they have any solutions
Profile closed
Not applicable
I tried to phone them, and they tried sending you new hub when it is not a hardware issue UPnP issue
I would log in to 192.168.1.254
  • Port 88 (UDP)
  • Port 80 (TCP)
  • Port 500 (UDP)
  • Port 3544 (UDP)
  • Port 4500 (UDP)
