EE app not showing Smart Wifi
GC_Wood
Valued Contributor
Valued Contributor
My broadband connection is working fine, but when I log in to the EE app, it is no longer showing my Smart WiFi devices, so I can't click on them to see which devices are connected via each access point.
I can tell that they are working, because if I click on a device it says "Connected to" and lists the Smart WiFi devices.
Where the Smart WiFi devices used to be listed alongside the Smart Hub Plus, there's now an option to "Set Up Smart WiFi", but that doesn't work because the devices are already set up.
Seems to be just another example of EE's awful software! Anyone got any ideas for how I can fix it, please?
You don't need the app to see that. Login to the router @ http://192.168.1.254 & look under Advanced > My Network & you'll see what is connected to what.
GC_Wood
Valued Contributor
Valued Contributor
Thanks, @XRaySpeX. This works, and I was aware I can do that. But if I'm accessing from my mobile device, it's much easier to use the app. It used to work, but like so many thinks EE software, it's decided to stop working!
