20-03-2024 08:48 AM
Hi I have been having the exact same issue, never had a problem with BT but switched to new EE broadband and can't connect the Xbox via ethernet cable and the app doesn't work so can't use the Gaming Mode, which was one of the main reasons we switched over
29-10-2024 09:42 AM
Hi, did you manage to get this resolved?
If so, how? Thanks
12-11-2024 09:37 PM
You're not alone with this!
12-11-2024 09:49 PM
Did you ever get this fixed?
17-11-2024 07:50 PM
Hi Matthew,
This problem seems to have started over the last couple of days, after months of it being absolutely fine.
Have you come across a fix?
20-11-2024 07:57 PM
Hi all
What worked for me was setting subnet port etc my self then allowing Xbox to automatically select subnet etc and then it worked.
27-03-2025 01:46 PM
Did you ever find out? As I'm now having the same problem!
