Port forwarding
djcrafty
Hello, need to open my port forwarding for black ops 6 on Xbox series x, got the hub settings and to the area where I can change but have no idea which numbers I need plus what protocol I need. Can you help, BO 6 is showing Strict, I was with BT and was able to open it all to have an open Nat type
8 REPLIES 8
@djcrafty : Whatever or whoever told you that you needed Port Forwarding should've also told you what ports need opening & their protocols.
Which EE router do you have (read label or post a pix)?
djcrafty
Hello, i’ve got the smart hub plus
Peter_W
Hi @djcrafty.
We have a guide here on how you can set up port forwarding on your hub.
As @XRaySpeX mentioned though, what you specifically need to open and the instructions will depend on the product / application you're doing this for.
Peter
djcrafty
Nat type on Xbox  series x call of duty, black ops 6. It’s set on strict and should be open
djcrafty
 EEC the port numbers ie one of them I know is 3074
djcrafty
djcrafty
This area
Fill it in with 3074 in all 4 port boxes. If you haven't been told the protocol use TCP/UDP.
