Is there a wireless link avaiable for my home phone if I cant connect by wire to
WWIIBaby
Wireless connect home phone to BT hub?
Peter_W
Hey there @WWIIBaby, welcome to the EE Community 😊
If you're using our digital home phone service, it'll depend on the model of phone that you're using here.
Some phones are able to be paired to your Hub directly via WPS, but this is only certain specific models.
You can still use a traditional DECT phone with this service too, though; just plug the base station into the green port on the back of your Hub, and this will work in the same way it does over the analogue phone network.
Our help page here should let you know all of the details you need!
Peter
Peter_W
Peter
Maestro
Maestro
@WWIIBaby Click on the link below and watch the video.
How to set up your Digital Home Phone - The EE Community
Have you got a digital phone adapter? You can plug that into a mains socket away from the router & connect it to the router by DECT wireless & then plug your phone into that.
