Landline
Pip-1960
Hi i changed from BT to EE recently as i had no choice. I was give there Smart Hub Plus which in my opinion does not work as well as the old BT Smart Hub 2. So i now want to use a third party router but landline needs Smart Hub Plus to make them work. I have read it is possible but complicated.
It is not possible with a 3rd-party router. The EE or BT Smart Hub must be the 1st closest to the incoming BB. You could have the 3rd-party router as a secondary router & use that for connecting devices.
So EE really have locked us down,both on this issue and their voicemail on the landline which at the moment cannot be switched off.
Cant wait for my EE contract to end. Other suppliers are available and will be looked at.
