Device unable to connect to new Smart Hub 7 Pro
MarkO21
I received my new Smart Hub 7 Pro, connected it all up and started to add devices to the new hub. It was going great but my Samsung Smart TV (which is over 5 years old) could see the network but wouldn't connect.
I did some searches on the internet, rebooting, manually adding IP address, etc but nothing was working. Then I found out, possibly on this forum, about devices running on WP2, the new Hub runs on WP3. So to make the Samsung TV work I had to create a compatible Hub name on WP2, so......
1. Open new URL https://192.168.1.254 to manage the router via the dashboard
2. Click on Advanced settings and log in with the admin password
3. Click on Wireless which takes you to the Advanced Wireless page
4. Near the top you see Main and Compatible Wifi options (Main is the one open), click on Compatible Wifi
5. You need to switch the Compatible Wifi button on.
6. The Wifi name is shown as [Hub Name}-Comp, I think you can change the name but I left it as that. Security Type is WP2-Personal which is what you want. I also copied the password form the Main page and added it to the Compatible Wifi password, you possibly can use your own.
7 Then go to the top of the screen and press the Save button.
8. Then go down and press the Start WPS
When you search for networks you should see this new Hub name as an option, my Samsung TV could see the network and was able to connect to the new Hub.
I suspect this will work with all older kit.
What device is it? Are all other devices OK?
Sometimes older or weaker devices may not be compatible with the default WiFi settings of EE Smart Hubs. Try setting up Compatible WiFi on the router under Advanced > Wireless Settings > Config > Compatible WiFi (it defaults to 2.4 GHz only & WPA2) & connect your problematic 2.4 GHz devices to that.
17 REPLIES 17
The TV is a SAMSUNG - UE65TU7020KXXU 65" Smart 4K Ultra HD HDR LED TV, everything else connected OK.
Yes, I know! I told you that when you 1st posted & well before you did your big edit.
Maestro
Maestro
@MarkO21For your next time instead off reinventing the wheel when it's all on the Help.
Connect your devices using Compatible WiFi | Broadband Help | EE
I have 3 tvs 2 samsung frames one LG tv and a nest thermostat that won't work with my new smart hub 7, have tried all of the above and then some, spent 5 hours on the phone with EE also had an engineer visit in the end they replaced the hub still the same issue says connected with no Internet.!!!
@Dez1uk Have you asked EE to allow you to test a EE Smart Hub 6 Plus version then, if you devices will not work on the Main ssid, or neither the Compatible network with a WPA2-Personal setting for the securities.... There is TWO EE 7 Devices now a 7 Pro and a 7 Plus, as you have used another post can you confirm what EE Hub you are using. Also say if any EE Extenders or third party devices are being used also.
What hub did you have before with all the devices you mention above working and connected?
I haven't but will give that a try, my previous hub was a sky hub wifi5 which I had no issues with. My current hub is the 7 plus no extenders used
@Dez1uk Thanks for the reply, so you more than likely had the Sky SR203 Hub, it is a MAX for wireless securities as WPA2-Personal THAT is as far as that unit goes.....
You either have an issue with securities on that 7 Plus version that you have now confirmed, or if you are using the app, look very closely that you have NOT done a group and applied those devices to security restricted, would be like parental controls area....
1. Check your parental controls first.
2. If above is good, you will have to set up the Compatible Network feature, and connect all those devices to that...
Link is above earlier in the thread how to setup and use.....
Hi Jim, EE are sending me a smart hub 6, I have changed the settings with the hub to wap2 to try and connect and I have not done a group the issue seems to be a firmware problem as the router says it's connected to one tvs and tvs to the router but nothing works! Frustrating hopefully the 6 solves the issue
