27-08-2026 04:59 PM
I am about to return to the EE fold and my full fibre broadband switches over tomorrow.
Now the cheap and cheerful Hub 7 is not sufficient for me so I have a higher spec 3rd party item that I wish to connect straight away.
To connect the alternative device I need the bb user id and pwd.
The hub 7 only comes with it's admin and wifi password card, this doesn't help me as I need the broadband connection password and associated credentials.
EE app is no use, the EE support line has an hour plus wait , how can I obtain the essential information I require to setup my equipment?
Any suggestions as I want to jump from current provider to EE and just change settings on my router to facilitate that without using the hub 7!
Thanks in advance
27-08-2026 05:05 PM - edited 27-08-2026 05:16 PM
@Demonix You just set as per the connection type from the help details below.
How Do I Use My Own Router for EE Home Broadband? | Broadband Help | EE
Do also suggest at sometime you follow and do the EE one, then box it back up.
27-08-2026 05:49 PM
Jim,
Thanks but I am already aware of the connection configuration for ppoe and 3rd party router, it's just my Connection credentials that are required and it's a nightmare trying to obtain them from EE!
Hub 7 is a "fallback" device box in the unlikely event my performance router has any issues or a door stop.
27-08-2026 05:51 PM
They are in that linked article:
Full fibre
- Username or login name - [email protected]
- Broadband password - BT or leave blank
- Authentication - CHAP
- DNS - auto or obtain from ISP
27-08-2026 06:03 PM
27-08-2026 06:05 PM
Generic account details and a blank password, that's not exactly secure ! I e. [email protected] etc.
Ee used to use proper individual user ids and a connection password. Had assumed that would be the case now?
27-08-2026 06:07 PM
@Demonix Not any more, you ONT is the block for connection so more than secure!
27-08-2026 06:11 PM
Ah ok thanks 👍 that makes sense now.
27-08-2026 06:12 PM
They are not meant to be secure. They are just a placeholder. Checks are done against the incoming line itself.
You can still use the old creds of yourname.orange-domain@fs & chosen pwd.
27-08-2026 06:16 PM - edited 27-08-2026 06:19 PM
@JimM11 : Not really the ONT. Consider that ADSL & FTTC would be using the same creds in the absence of ONTs.
Nice guess again but way off as usual.
