07-06-2024 02:08 PM
We have a video covering how to setup and connect a variety of phone types to your Smart Hub. This covers corded, cordless and EE digital home phones. This works if you have a BT digital voice phone or adapter, as well with most third party devices.
This video covers:
25-08-2025 12:16 PM
I've just switched to EE from BT broadband + digital home phone.
My cordless home phone is situated in the hall, a few metres away from the router.
I've been using a BT adapter to enable this. Should this still work with EE?
I've followed the instructions in the video. I assume the green light on the adapter should glow solid green? Even when plugged into a socket right next to the router, I can only get it to flash green, and when I plug the landline into the adapter, predictably, it doesn't work.
Am I missing something? Do I need an EE adapter?
25-08-2025 12:20 PM - edited 25-08-2025 12:32 PM
@andyturner1960 Takes a couple off day's for the old switchover from landline to the DV side so you may just be jumping the gun. Will find again and link the DVA, but if you are so close, plug the phone into the back off the hub, and put the DVA away in a drawer! Your choice but personally would advise go get a couple metre phone extension cable!
What your Digital Voice
Adapter light means
1 On initial plug in – flashes 0.5 seconds on,
2 seconds off
2 During registration – flashes quickly
0.5 seconds on, 0.5 seconds off
3 Once registered – stays solid green
4 During a call – flashes slowly 1 second on,
1 second off
5 Once registered, if there’s a connection
problem with your broadband – flashes
0.5 seconds on and 2 seconds off.
Maximum Digital
Voice devices
You can register a maximum of 5 Digital Voice
devices (that includes Digital Voice Handsets
or Digital Voice Adapters) to your new Hub at
one time
25-08-2025 12:22 PM
Thanks Jim, but our switchover was last Wednesday.
And where I want the handset base unit is only a few metres, but too far to run a cable from the Smart Hub.
25-08-2025 12:35 PM - edited 25-08-2025 12:35 PM
@andyturner1960 Plug the phone into the back off the Router, and see if it is at least working!
25-08-2025 01:32 PM
Yes - no problem when connecting it direct to the Hub
25-08-2025 02:18 PM
@andyturner1960 There should be no issue then pairing the EE/BT DVA to the Router, Time to say which model off the EE Router that you have, link below shows you the current models! Depending on the model you may also have to web interface to the EE Router as the WPS button may not be functional for the pairing option!
28-08-2025 06:11 PM
The EE Router is a Smart Hub Pro, Model SH40J.
The Digital Voice Adapter is model no. X16-G90, supplied by BT.
28-08-2025 06:58 PM
@andyturner1960 Have not a clue about the smarthub Pro, when you press the WPS button does the light on the front off the hub indicate it is in WPS mode, if not then there is an enable button in the web interface to start the WPS Mode off. Advanced wireless, and http://192.168.1.254 to get to it worth a try! BT/EE DVA are reported to be the same! And plugged into the back you do have an enabled DV system!
14-01-2026 04:11 PM
I have just been sent the EE digital home phone handset following installation of EE broadband in December and my old Panasonic handset no longer working. I was able to link the EE handset to the hub as instructed in the user guide, and for a short time the handset seemed to be working. However it is now coming up with a message saying No Link to the Hub and I am unclear as to what I should do to correct this. The home phone is situated in a different room from the hub/router. I sited the handset next to the hub for a few hours to see if it would link but it didn't. (I assume with this handset I do not need to use the digital adapter which I was sent to use with my old Panasonic? in any case there seems no way of connecting this handset to the adapter). Please can you advise?
