Slow speeds
WMAXH10
I am 100 mtrs from dslam but my speed averages 48Mbps download.  Tracert test shows issues within the network,
The issue is clearly a network issue, having many years as a broadband engineer for BT. I am aware of possible problems but the engineers do not seem to think beyond their JDSU
please investigate the network.
[Mod edit: removed personal details]
Christopher_G
Hi @WMAXH10
I definitely recommend following @JimM11's advice and speak with our technical support team. They'll be able to look into this from our end and book an engineer visit, if needed.
Let us know how you get on please.
15 REPLIES 15
Maestro
Maestro
@WMAXH10 The Forum is public and not EE CS, you need to call EE direct or if on the new system do the HELP to 66033 as a text message if your mobile device can do it. No investigation will be done from your posting. EE are closed now so 8am tomorrow morning onwards for your call or text to them.
What are your router connection stats?
What speeds are reported by running the speed test in the EE app? That will not only measure the raw BB connection speeds you are getting at the router as well as speeds to the device from which you are testing.
Maestro
Maestro
@WMAXH10 Nothing wrong with your tracert's you did, as @XRaySpeX has requested better to get your stst's from the Advanced Status captured and posted, https://192.168.1.254 to get on the web manager.
If you are correct and only 100M from the street cabinet, your sync should be up at the 80Mb/s down - 20Mb/s up unless you have some cable wiring issue home, street to the cabinet etc being that close. Will copy all the tracert's below in a separate for you. If you say which EE/BT hub you are using can show you what would be best, got EE and BT hub captures.
Your OR colleagues may be required to error check your fttc line connection, but there will be some other things you can do once your stat's are looked at.
Maestro
Maestro
@WMAXH10 Captures and posted pics.
Microsoft Windows [Version 10.0.26200.8737]
(c) Microsoft Corporation. All rights reserved.
C:\Users\>tracert amazon.com
Tracing route to amazon.com [98.87.170.71]
over a maximum of 30 hops:
1 1 ms 1 ms 1 ms ZenWiFi_XT8-BBD0 [192.168.xx.x]
2 248 ms 205 ms 151 ms 90.247.128.1
3 13 ms 12 ms 13 ms 63.130.172.35
4 12 ms 12 ms 13 ms ae5-100-xcr1.man.cw.net [195.89.96.113]
5 86 ms 85 ms 85 ms ae1-ucr1.bsh.cw.net [195.2.27.193]
6 19 ms 19 ms 18 ms ae20-xcr1.slo.cw.net [195.2.10.130]
7 100 ms 85 ms 84 ms ae18-xcr2.nyk.cw.net [195.2.28.169]
8 * * * Request timed out.
9 * * * Request timed out.
10 * * * Request timed out.
11 * * * Request timed out.
12 * * * Request timed out.
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
C:\Users\Ji>
C:\Users\>tracert bbc.co.uk
Tracing route to bbc.co.uk [2a04:4e42:200::81]
1 1 ms 1 ms 1 ms 2a0a:ef40:6b2:da00::1
2 209 ms 270 ms 257 ms 2a0a:ef40:ffff:16::1
5 12 ms 13 ms 12 ms 2a04:4e42:200::81
Trace complete.
C:\Users\>
C:\Users\>tracert bt.com
Tracing route to bt.com [45.60.65.23]
1 1 ms 2 ms 1 ms ZenWiFi_XT8-BBD0 [192.168.xx.x]
2 16 ms 63 ms 40 ms 90.247.128.1
3 14 ms 14 ms 15 ms 63.130.172.45
4 16 ms 17 ms 17 ms linx-224.retn.net [195.66.224.193]
5 31 ms 19 ms 18 ms ae3-5.rt.eqx.slo.uk.retn.net [87.245.234.139]
6 16 ms 16 ms 17 ms gw-as19551.retn.net [87.245.230.55]
7 16 ms 17 ms 17 ms 131.125.135.75
8 17 ms 16 ms 17 ms 45.60.65.23
Trace complete.
C:\Users\>
C:\Users\>tracert google.com
Tracing route to google.com [2a00:1450:4009:c0b::8b]
1 2 ms 1 ms 1 ms 2a0a:ef40:6b2:da00::1
2 6 ms 4 ms 4 ms 2a0a:ef40:ffff:16::1
3 16 ms 15 ms 14 ms 2a0a:ef40:fffe:505::2
5 17 ms 19 ms 19 ms 2001:4860:0:1::4b49
6 18 ms 16 ms 16 ms 2001:4860:0:1::46c0
13 20 ms 18 ms 20 ms wj-in-f139.1e100.net [2a00:1450:4009:c0b::8b]
Trace complete.
C:\Users\>
AmazonBBCBTGoogle
BT tests the line with the usual basic tester, probably a TAM test which I had found for the number of years as a broadband engineer for BT,  part of the dedicated BB team for Birmingham and Coventry. I have suspicions that a line fault has developed, possibly a split pair with other issues adding to it.
Trying to get the 'technicians' to go as far as I used to for my broadband customers, was known as the BB miracle worker in the local military base near Gaydon.
there is something wrong but I just get quoted the guaranteed speed which covers the furthest reaches of the local Dslam, NOT the closest speeds.
sorry BT, you are failing to provide a proper service.
averaging about 42 Mbps download and 8.5 upload speeds
used to get 80 Mbps and 19 Mbps
getting almost 60% now
not a happy bunny
@WMAXH10 What is your fall back min speed on the line, see the btw and use your address. Have you tried your test socket? It's an OR Openreach problem to fix, BT got nothing to do with this one... Miracle works cost a little extra if you can find a good copper one now, Ex military one you will be good to go, they do know what they are doing.... And sorry from me, thought i had posted and attached the picture ref to look at with the web manager interface, https://192.168.1.254
BT Broadband
Screen to check on your EE Hub.
LordMatt
Wanna swap? My top speed is 20Mbps and sometimes it is as low as 250Kbps.
The only thing I like about EE is that their staff are generally nice people.
@LordMatt Would you like to throw up your sync speed from your EE Hub so it can be looked at? At 20Mb/s you must be a good distance away from your street cabinet, or you possibly just have a bad line, the BTW link will also indicate what is expected. Just hide any details if you decide to post. Building Number and postcode is generally all that is needed for the check.
BT Broadband
