Replacing my EE Router with Google Nest Wifi Pro
gossipgirl
Hi there!
I’m trying to set up my Google Nest Wifi Pro, but I’m having trouble with the settings. It’s asking for some information, and after checking a few articles, I found that the default PPPoE password might be "BT" or empty. However, when I checked my hub’s admin settings, it said, “The password is not displayed for security reasons.”
What I’m hoping to do is remove the EE Smart Router entirely and connect the Google Nest Wifi Pro directly to my Openreach GPON terminal. I really need help with the correct setup with the WAN settings.
Any assistance would be greatly appreciated. Thanks in advance!
12 REPLIES 12
@TackyAuto wrote:
EE support just advised bridge mode
Bridge mode for what? EE routers don't have a bridge mode. They should know that, silly billies!
I hadn’t actually checked that but seems ONT direct doesn’t pick up either so not sure what’s going on but I’ll try another solution I think lol
@TackyAuto You may wish to Factory Reset your Google Nest (Non Pro version) start again set the wan for PPPoE operation
The User as [email protected] and the Password as BT.
Then also consider the ONT and the Nest off for 30 mins so the system can start fresh with the both devices, ONT on when lights go green after a few minutes, Nest on and allow five mins to see if it connects.
