Wrong location
RozM
Has anyone had problems with their router giving the wrong location?
My router seems to think I'm in Bridgend, near Cardiff, when I'm at the opposite end of the country!
Using any mapping software (Google maps, MapQuest etc) always shows me in Bridgend.
I've powered the router off several times but no luck in fixing the problem.
Maestro
Maestro
@RozM Try IP Location - Instantly Locate Any IP Address to see where it thinks you are.
Geolocation is not an exact science. EE issues you with a public IP Addy which comes from a pool of IPs that are registered to EE at any point of the country.
What are the 1st 3 parts of your public IP, which can get from WhatIsMyIP  ?
