Can’t created Verified ID
jxmes23
I’m trying to create the ID so i can activate a sim plan with EE but it keeps saying something went wrong and to try again later. it’s been 48 hours and still won’t work. how do i fix this
Christopher_G
Hi @jxmes23
Welcome to the community.
The only thing I can see that may make a difference, is the Do Not Disturb facility is active. Although it probably won't make a difference, please try again with it disabled. It also may be worth trying it over the mobile network, rather than over WiFi.
If you're still having problems, I recommend speaking with our customer support team so they can try and activate it from our side for you.
Christopher_G
Hi @jxmes23
