on 29-11-2025 10:42 PM
Hello
I have been with EE for broadband for about. a month now and I am having issues with ethernet Connection. It frequently disconnects and only comes back on if I reset the ethernet network adaptor on my pc, or if I hit the reset button on the hub.
I have tried 2 different ethernet cables now and still no luck.
I didn't have this problem previously when I was with Virgin so I assume it is the hub and not the PC that is causing the issue.
Any ideas?
30-11-2025 07:49 AM - edited 30-11-2025 08:08 AM
@PcGamer1 What EE Router are you talking about, few different ones, linked below about so look see!
Also have a read to see, has switch and cable depending on what would work best
Solved: EE Smart Hub Pro – Ethernet Ports Dropping Connection Overnight - The EE Community
on 30-11-2025 08:16 AM
Hi Jim
I have the Smart Hub Plus. Very frustrating at the moment.
Thank you for the links, I will have a read
Stuart
on 30-11-2025 08:28 AM
@PcGamer1 There is a known issue with all the EE Smarthub+ Ethernet ports, but it is normally just the connection time for the 20/30 second delay, and once the port is established it normally holds very well, so a little concerned that you keep dropping but sure fire way to test it is do not power off the Router or the PC, just pull the Ethernet cable off, wait 10 seconds plug it back in then 20/30 seconds latter see if your device connects again fine.
PC related then you may have to look at the adapter properties tweak values but do them one at a time and if same return it back to what it was before... Switch get's rid off the delay as it is always on so instant connect!
