on 31-07-2024 02:37 PM
Hi
I have recently had the 1.6Ggps broadband fitted but can only get around 940 Mbps.
I am using an ASUS Router GT-BE98 that has multiple 2.5G and 10G connections with a Cat 7 cable going directly to my PC with a ROG Maximus Hero Z790 motherboard which has a 2.5 G built-in Intel 1226-V ethernet controller (with updated drivers). I have changed the cable going from the open reach box to the ASUS Router to Cat 7. I have changed my PC ethernet controller Advanced options to 2.5 Gbps Full Duplex but I can still only get around 940 Mbps and the Link Speed in the Windows settings shows 1000/1000 (Mbps).
Can anyone help please?
Paul
Solved! Go to Solution.
on 10-08-2024 12:09 PM
OK, so after an EE Engineer came out and referred it back to Openreach, an Openreach engineer called out this morning and replaced the ONT which she said was faulty.
The result is below
Hurrah! Thanks to everyone for their Help and advice.
on 31-07-2024 02:50 PM
Are you sure you have the 2.5 Gig ONT fitted there?
.What does the router report as its WAN connection speed?
on 31-07-2024 02:55 PM
If windows reports your LAN is only at 1gig then it doesn't matter about the WAN side until you resolve the LAN issue.
on 31-07-2024 03:01 PM
Hi
I didn't realise there were different types of ONT and assumed if I was being offered 1.6 Gbps it would be capable of that. Can you tell from the picture please?
on 31-07-2024 03:12 PM
Hi
Thanks - any ideas what issues would cause the lan to show as 1000Mbps when all the hardware supports 2.5G?
Paul
on 31-07-2024 03:22 PM
From what I can see this is a Nokia ONT and if the connection is orange it should be 2.5G Model. I think this looks orange.....
31-07-2024 04:03 PM - edited 31-07-2024 04:51 PM
Obviously if the WAN is limited to 1 Gig nothing else can run at more than 1 Gig. Then there's no LAN issue and the root cause is the limited speed WAN i.e. a 1 Gig ONT.
on 31-07-2024 04:27 PM
@paulmccarrison2 That does look like it is a 2.5Gb ONT, you can see a clearer pic in this thread.
https://community.ee.co.uk/t5/Broadband-Landline/1-6Gb-Package-Well-the-day-came/td-p/1347588/page/2
Which ports are you using on the router? From the specs:
1 x 10Gbps for WAN/LAN
1 x 2.5Gbps for WAN/LAN
1 x 10Gbps for LAN
3 x 2.5Gbps for LAN
1 x RJ45 10/100/1000Mbps for LAN
I would start with the ONT in the 2.5Gb WAN/LAN port, and your PC on one of the 2.5Gb LAN ports, and check the router has negotiated both at 2.5Gb.
I beleive someone had a similar issue which was down to using the wrong ports.
on 31-07-2024 04:59 PM
Still worth checking router's WAN connection speed. Then you'll know which side the issue lies on. For all you know EE may only be sending you 1 Gig BB.
on 31-07-2024 07:51 PM
Hi I think I have everything connected correctly but no improvement in speed
