on 31-07-2024 02:37 PM
Hi
I have recently had the 1.6Ggps broadband fitted but can only get around 940 Mbps.
I am using an ASUS Router GT-BE98 that has multiple 2.5G and 10G connections with a Cat 7 cable going directly to my PC with a ROG Maximus Hero Z790 motherboard which has a 2.5 G built-in Intel 1226-V ethernet controller (with updated drivers). I have changed the cable going from the open reach box to the ASUS Router to Cat 7. I have changed my PC ethernet controller Advanced options to 2.5 Gbps Full Duplex but I can still only get around 940 Mbps and the Link Speed in the Windows settings shows 1000/1000 (Mbps).
Can anyone help please?
Paul
Solved! Go to Solution.
on 02-08-2024 12:37 PM
If your PC is saying 1000/1000 you're chasing your tail trying to get anything more. There's clearly an issue between the PC and router. As someone else said, you need to get a 2500Mb connection to your router being reported by your PC.
on 02-08-2024 12:40 PM
on 02-08-2024 04:11 PM
Hi
Sorry I should have mentioned that I subsequently attached my windows laptop and MacBook using a 2.5g USB dongle and both showed a 2500mbps connection but would only download at around 940mbps maximum.
Paul
on 05-08-2024 03:52 PM
I have now reconnected my EE Hub and this is what I am seeing in the seeing - they have told me that they have sorted out my account problems....Should the WAN links speed show higher?
on 05-08-2024 04:07 PM
@paulmccarrison2 When did you reconnect the EE router time/date wise, and when were you told that EE had sorted out your account?
on 05-08-2024 04:14 PM
At last! There, that proves it. As you have a 2.5 Gig ONT, EE are only delivering you with 1 Gig BB.
on 10-08-2024 12:09 PM
OK, so after an EE Engineer came out and referred it back to Openreach, an Openreach engineer called out this morning and replaced the ONT which she said was faulty.
The result is below
Hurrah! Thanks to everyone for their Help and advice.
on 10-08-2024 12:19 PM
@paulmccarrison2 thanks for coming back and letting us know what the issue was.
Hopefully you can now enjoy the faster speeds.
on 11-08-2024 07:56 AM
@paulmccarrison2 If you have time, can you also post an updated status page to display the sync speed 1.6/1.8. Thanks
on 14-10-2024 01:50 PM
If it's the black router they have sent you the wrong one. Had same issue but my router has been replaced. Black router gives Max 1000mbs on internet cable. You need the pro 7 which is white and is the newer routers will get your speed.
