23-02-2024 08:25 AM
Newtork Interface eth 1, 2 or 3, keep going down and up is this normal and what does it mean? Is the hub bringing them down and up?
The hub is the EE Smart Hub Plus, the latest one
Here is just an example but there are many, many lines of this:
23/02/2024, 07:37:00 | Network interface eth3 down |
23/02/2024, 07:36:03 | Network interface eth3 up |
23/02/2024, 07:35:59 | Network interface eth3 down |
23/02/2024, 07:35:02 | Network interface eth3 up |
23/02/2024, 07:34:57 | Network interface eth3 down |
23/02/2024, 07:34:00 | Network interface eth3 up |
18-07-2024 06:09 PM
I waited for a firmware upgrade to the EE Smart Hub and it seems to not be a problem any more
21-07-2024 07:48 PM
Can you please give me the current firmware version with which your router is loaded?
21-07-2024 07:54 PM
r1.34.1-R-1055417-PROD-83002
13-11-2024 04:13 PM
I'm having this same issue, all my ethernet ports are turning off. When I switch the TV on I get an error message saying Ethernet Not Connect. I have to wait several minutes before I can use the TV. The same games for my XBOX, it says you are not online again have to wait for the connection. When TV and Xbox are in use, I have no issues. It's only when they are switch off.
My firmware version is this- r1.35.0-R-1138091-PROD-83002
My firmware has never been updated. How do I download and install the latest firmware?
13-11-2024 05:08 PM
I was told there is no way for a user to force an upgrade, they just happen when EE decide. To my knowledge this is still the case.
13-11-2024 05:14 PM
@Eddie42-1 : You have the latest.
14-11-2024 08:27 PM
Thanks for the response
14-11-2024 08:28 PM
So, is if I have the latest firmware but still having this issue. Do I have a faulty router?
19-11-2024 07:08 AM
got exactly same issue, on my second router and still same issues. connection doesnt drop on wifi but turns off on ethernet connections to x2 ps5`s, seems to be a router software issue
19-11-2024 03:33 PM
Welcome to the community.
Have you spoken with our Technical Support team? They'll be able to check everything from our side and run through some troubleshooting with you.
