23-02-2024 08:25 AM
Newtork Interface eth 1, 2 or 3, keep going down and up is this normal and what does it mean? Is the hub bringing them down and up?
The hub is the EE Smart Hub Plus, the latest one
Here is just an example but there are many, many lines of this:
| 23/02/2024, 07:37:00 | Network interface eth3 down |
| 23/02/2024, 07:36:03 | Network interface eth3 up |
| 23/02/2024, 07:35:59 | Network interface eth3 down |
| 23/02/2024, 07:35:02 | Network interface eth3 up |
| 23/02/2024, 07:34:57 | Network interface eth3 down |
| 23/02/2024, 07:34:00 | Network interface eth3 up |
22-11-2024 11:46 AM
all the lights are fine on the ont and modem/router.
22-11-2024 11:53 AM - edited 22-11-2024 11:55 AM
@Mikeharris1971 Use a web browser and http://192.168.1.254 and click on the status screen, i will post a link to my picture below so you can compare, speed at 1000/2500 you do not want to see 100. Page picture link below
22-11-2024 11:56 AM
i got 1000mbps.
22-11-2024 04:37 PM
@Mikeharris1971 Sorry, missed your reply, must have been coming in as i was sending the edit to you. Your EE Router and the ONT are connected at max speed, to test your PS5 cable to the EE router, i believe that there is something in the PS5 around network settings that test's the network speed, if you get below the 100 then bad cable, anything above then nothing to do with the cable. Run that test, not a PS5 user, but son is so have seen it done.
22-11-2024 09:05 PM
I have done the test and getting 920 download and 110 upload so no issues there. That's what they are saying I should be getting.
22-11-2024 09:15 PM - edited 22-11-2024 09:17 PM
@Mikeharris1971 That would be correct and good, so now we know that the port is good and the suspected cable issue on your home report from EE, was/is the issue as reported network ports switching off as per the original OP posting?
