New Pro Firmware r3.8.24-R-1531355-PROD-1 for router and extenders.
tnj
Skilled Contributor
Skilled Contributor
This morning there is new Pro router firmware r3.8.24-R-1531355-PROD-1 and it starts by saying use HTTPS which is then says is not available. It then requires the admin password to get into any level of access. Now testing out what it does.
It allows you to set your own DNS servers in DHCP.
It still does not let you lock the 2.4G WiFi to a channel, it keeps reverting to Channel 11
131 REPLIES 131
Huggons1
Possible I guess, but never came across this before with any of the EE routers.
Hoping to receive the update soon.
@Huggons1 If EE have pulled the FW updates for possible issue then nothing else will be sent out, those that are there stay as is so not sure if they even support a rollback FW feature but would be shocked if it did! As nothing else seems to have jumped out on the Forum then again not many possibly even look at it!
