‎24-04-2025 10:01 PM
Hello all,
I've got an odd issue which I'm hoping someone can offer a steer on.
I have the EE 1.6 Gb Full Fibre Busiest Home package with a Smart Hub Plus.
All seemed to be working fine until my original Smart Hub Plus failed in Jan 2025. This was attributed to a bad firmware update, and a new hub was sent out. I connected this up and again everything appeared to be ok, until colleagues at work started complaining that my video during MS Teams calls was regularly freezing. On my end, I didn't see any issues - I could see and hear everyone else fine so it came as a surprise. Setting up a test meeting that just included me, I recorded myself and when playing back immediately found that the video and audio both freeze and stutter. This is readily reproducible, although sometimes the performance is extremely bad with the video completely frozen. Strangely, this only affects the MS Teams desktop app, with connections via the web browser still being good quality.
So far, everything else seems ok - stable and fast connection (getting around 1.6 Gbps routinely).
Here's what I've tried so far:
This suggests to me it might be some network infrastructure issue, rather than a problem with the Smart Hub Plus or with the laptop / Teams. Could the route the traffic is following make a difference? If so, how would I go about pinpointing this? The Microsoft 365 connectivity tests don't flag up anything obvious.
After much testing to convince myself there was an issue with the connection I called EE and an engineer visited. He indicated there had been some problems with the Smart Hub Plus on fast connections, tried to run a series of tests but these didn't complete. Reason unclear. However, he was confident that the new Smart Hub Pro would resolve the issues although he wasn't allowed to issue one himself.
Engineer left, job appeared to be closed, then I got a message from OpenReach asking me to arrange a call so that equipment could be delivered. I did, got put through to EE, with the guide saying that I really should have had the Smart Hub Pro already and that he'd get one sent out, although the process for doing this was very difficult. That was almost a couple of weeks ago. Being concerned this wasn't being progressed I got back in touch - over multiple calls now, once I get past the agent telling me I've got a very fast connection and they can't see an issue or find open jobs, when they review previous notes there's a record somewhere to an order being placed, but no-one can find out what. It appears I'm now down as a new customer and something needs to be progressed by the "New IT" team, even though I've been with EE for over a year.
So, perhaps a Smart Hub Pro will be sent out, which will be good because it sounds like I'm entitled to one on my package.
However, I'm not convinced the hub itself is the issue, given that the Asus router performs similarly, except when a VPN is active.
Does anyone have any thoughts about what might be happening?
Thanks!
‎01-09-2025 04:50 PM
Hi, did you manage to resolve this? I have the same issue and I used a new router Deco xe75 and connected it directly to the ONT.
Used PPOE but the only way teams video calls and screen sharing work is if I link my deco to nord vpn and activate the connection to my laptop?
its so weird and I don’t want to give customer services a call as I fear I’ll be dragged around in circles
‎01-09-2025 07:52 PM
Unless you call EE Customer Services, they won’t know you are experiencing an issue with Teams. My suggestion is to give them a call. Based on this thread alone, it seems at least they are aware of problems.
‎03-09-2025 02:03 PM
Good Afternoon, all
This is going to be a long response but an important one. As you can see from my previous messages I've also experienced the issue with Teams/Zoom & Webex calls being really poor when moving from BT to EE. I work for an Analytics company that specialize in Teams data so ran the software against my calls and found that I was seeing High Audio Packet Loss, High Video Packet Loss which all points to the network being unable to handle the packets properly.
Looking at this data, I hadn't had a single issue at home until 9th June when I moved to EE, since that date nearly all my Teams calls were affected.
Speed testing with FAST or similar showed everything was fine (950 down, 110 Up). Even Microsoft's own testing APP came back clear but when I joined calls everyone was saying how bad my voice/video was & often sharing screen didn't work or my video didn't appear at all! I could easily prove this by running a "Meet Now" meeting and recording myself which proved how bad it was.
Logged the issue with EE several times, had an engineer out and everything but no changes to the service. I work from home in a Sales capacity & this was now causing me major grief!
Finally managed yesterday to get hold of a very helpful man who agreed to send me out an old BT Smart Hub . Installed this morning and I've run several "Meet now" tests and tests with colleagues and the problem has totally disappeared.
So, my belief is the EE Smart Hub SH32B is the issue. What I think might be happening is that the Smart Hub is trying to honor QOS markings from Teams/Zoom/Webex and somehow completely messing it up. Older routers don't do this & that seems to be a good thing in this instance.
So, that's my formal update. Do with it what you will.
‎05-09-2025 11:32 PM
Seems to be an issue with any router thats been in the market for recently. I switched to the DECO XE75 and the issue still persists.
Gave EE customer services a call and they have logged a ticket with this forum as a reference to figure out what is going on.
Fingers crossed they do something about it.
‎06-09-2025 01:50 PM
Thanks Tryfan for the detailed email, I totally agree thats sounds QOS thing.
I never got a callback from EE on registering this issue 2nd time.
Remember asking the tech support to strip all off the line - parental controls and any layer 7 filtering. So had the same replacement for router (power issue). about a month and same issue is there. It’s shame the didn’t sent they new WiFi 7 router for me to test. A friend of mine had excellently same power issue the other day, but the only sent him power plug not a new router.
Not sure, if i mention in previous post, that i had BT open reach engineer ages ago and we both tested the line using ethernet. The physical line was ok, but virtual circuit came back as inconclusive. As BT only responsible for the physical infrastructure. Originally when the replaced my NTE to 2.5GIG from 1 gig one for 1.6 from 900mb BB. The BT engineer was here for 4 hours and really struggled to get it working.
I’m thinking one just renewing this March with 300mb offering, opposed to the 1.6 Gig offering.
My work laptop still works perfect on office WiFi and teams on my ZEN 300mb BB Fritz router.
Sorry I went on a bit of rant here.
Tom
‎23-09-2025 12:39 PM
Did you ever get this sorted??
We have the same issues and Ive spent hours on the phone to "Technical"
Have a 900mb download & 109 upload and teams constantly freezes.
New Ethernet cable plugged directly into the router from the laptop.
We have to use our hotspot on our phone to use teams.
‎04-10-2025 10:36 AM
I have has the same problem for months now. In summary I now have a workround which is to use a VPN.
I have had a replacement hub installed - no improvement.
I have replaced the ethernet cables - no improvement
I have tried a different machine (a MacBook rather than a PC also wired in by a different ethernet cable) - no improvement
I have used Teams meetings rather Teams calls - works fine. It appears that
I have discovered that MS Teams calls use a peer to peer connection (using wither UDP or TCP) where as Teams meeting uses Microsoft’s cloud conferencing infrastructure in which both sides connect via HTTPS (using TCP on port 443) and then use UDP to and from the server for the media. Hence the quality difference between Teasm Meetings and Teams Calls.
This all points to a problem on EE side with handling peer to peer connections. But trying to get hold of anybody on EE who is capable of even understanding the problem, let alone resolving the issue is proving impossible. EE are proving themselves incapable of providing reasonable care and skill in the provision of their broadband product and I would argue are therefore in breach of their contract.
‎12-10-2025 08:07 AM
Hi Quantumphys,
I have a similar issue that affects MS Teams Calls bu not MS Teams Meetings. MS Teams calls use a peer to peer connection rather than going via server which is what happens in Teams meetings. The download is unaffected but the upload (i.e. the quality of your audio and video that the other person hears and sees is badly affected).. The issue apears to be related to a number of a number of EE users in diffrent pockets of the country and I suspect is related to the incorrect configuration of routers inside certain local exchanges which are what is called "dropping UDP packets" on the upload.
To cut to the chase there are two work arounds:
1) Schedule all MS Teams calls as MS Teams meetings OR
2) Buy and install a VPN which will by pass your allow your UDP packets to be tunneled and therefore by bypass your faulty local exchange router. There is an overhead using this approach so you will lose a bit of bandwith but I think this is the best work around.
I hope this helps.
‎26-10-2025 09:23 PM
As per my post on another thread on this subject, the last bit may be useful for you folks-
This issue is a nightmare. Unfortunately no-one gets any traction as I believe it is a limited number of customers that realise this is an EE problem and end up here... I think this is an issue isolated to secure corporate laptops as others in my house have no issues - but for me, attempting to share is basically a no-go and causes my video feed to crumble.
Interestingly -my employer (large corporate, tens of thousands of employees) now have a message on their IT support pages stating this is an EE problem and effectively EE are not recommended to work from home.
It is really so annoying when the service is otherwise flawless.
However I hope this is useful - the workaround I have found is to stop using the Teams app altogether at home, and use Teams entirely from the browser (Edge for me). It takes some getting used to but it actually works...
‎06-11-2025 02:09 PM
Hi
Having very similar issues, everything fine apart from running Camera or Sharing content on Microsoft Teams for both myself and my wife.
I work in IT for a large organisation and its a known issue with a firmware upgrade on the router. I have been through the hoops with EE as previous BT router worked fine but they refuse to acknowledge the issue and blame Microsoft. Requested an older router but they won't issue one, won't let me out of the contract either. Has anyone managed to get a fix for this that has worked.
