Re: Laptop not seeing EE Network
Labroenstein
Hi all,
Now I am not sure if this is a dead thread. It has been a horrendous day setting up my EE WiFi with extender problems etc
My Laptop is old 2016, but currently running on Windows System: Windows 11 Home. I refuse to replace my laptop, because it works fine and maybe one day we will share a drink if it survives 8 more years (fingers crossed).
But, I had the same issue that my laptop was unable to see my EE WiFi connection, but could see everybody's down the street.
Route cause: Network Adapters "Intel(R) Dual Band Wireless - AC 7265" latest drives did not support the fancy new WiFi connection.
Fix: Within Device Manager, rolled back my Network Adapter driver to previous version and it worked.
Steps
  • Access Device Manager, within Windows 11 home, this is done by right clicking on the taskbar windows icon.
  • This will open a separate window with a list of options, select "device manager" opening the device manager window.
  • Selected the drop-down arrow next to "Network Adapters", expanding the list.
  • On "Intel(R) Dual Band Wireless - AC 7265" or you networks adapter card, right click to open a new window list.
  • Select "properties", this will open another window.
  • Within "Intel(R) Dual Band Wireless - AC 7265" properties window, select "Driver" tab
  • This will showcase a number of options, select "Roll Back Driver" and presto it worked for me. It rolled back my driver to 19.51.15.3, driver date: 24/02/2016.
Hope the above helps, maybe it is called windows, because the amount you need to go through to do anything. Wish me luck, going to try connect my printer to the EE WiFi.
In addition, Microsoft next time you do a systems upgrade, please get someone who uses a computer to design the UX. Simple is best to navigate (KISS).
bobpullen
Useful info that will hopefully help somebody 🙂
Worth noting that the reverse can sometimes be the case with these cards too i.e. they can't see WiFi 6/AX networks until the driver is upgraded. Plenty of evidence out there on the Internet, e.g. here.
bobpullen
