Microsoft Teams Quality Issue
QuantumPhys
Hello all,
I've got an odd issue which I'm hoping someone can offer a steer on.
I have the EE 1.6 Gb Full Fibre Busiest Home package with a Smart Hub Plus.
All seemed to be working fine until my original Smart Hub Plus failed in Jan 2025. This was attributed to a bad firmware update, and a new hub was sent out. I connected this up and again everything appeared to be ok, until colleagues at work started complaining that my video during MS Teams calls was regularly freezing. On my end, I didn't see any issues - I could see and hear everyone else fine so it came as a surprise. Setting up a test meeting that just included me, I recorded myself and when playing back immediately found that the video and audio both freeze and stutter. This is readily reproducible, although sometimes the performance is extremely bad with the video completely frozen. Strangely, this only affects the MS Teams desktop app, with connections via the web browser still being good quality.
So far, everything else seems ok - stable and fast connection (getting around 1.6 Gbps routinely).
Here's what I've tried so far:
  • Updated Teams and all drivers on laptop.
  • Direct cable connection to router with WiFi turned off and all other devices disconnected. No difference.
  • Laptop on WiFi on corporate network - absolutely fine, no surprise.
  • Laptop on WiFi in various coffee shops and on friend's home broadband - all much slower connections than mine and Teams is absolutely fine. Often extremely good.
  • Used phone as 4G hotspot - absolutely fine - extremely good video and audio.
  • Replaced the Smart Hub Plus with an old Asus router I used with a previous ISP - connected to ONT. Connects via PPPoE fine with reasonable speed (around 750 Mbps although using 2.5G port as WAN port, so a little surprised it's not faster).  Connection appears very stable and no obvious issues shown by ThinkBroadband BQM. However, Teams behaves exactly the same as with the EE router - terrible video and audio.
  • Configured Hotspot VPN on Asus router - set location to South England. Connection speed is around 100 Mbps. However, Teams now works absolutely fine. Very good audio and video. Turned off VPN - fast connection restored and Teams video and audio revert to being terrible.
This suggests to me it might be some network infrastructure issue, rather than a problem with the Smart Hub Plus or with the laptop / Teams. Could the route the traffic is following make a difference? If so, how would I go about pinpointing this? The Microsoft 365 connectivity tests don't flag up anything obvious.
After much testing to convince myself there was an issue with the connection I called EE and an engineer visited. He indicated there had been some problems with the Smart Hub Plus on fast connections, tried to run a series of tests but these didn't complete. Reason unclear. However, he was confident that the new Smart Hub Pro would resolve the issues although he wasn't allowed to issue one himself.
Engineer left, job appeared to be closed, then I got a message from OpenReach asking me to arrange a call so that equipment could be delivered. I did, got put through to EE, with the guide saying that I really should have had the Smart Hub Pro already and that he'd get one sent out, although the process for doing this was very difficult. That was almost a couple of weeks ago. Being concerned this wasn't being progressed I got back in touch - over multiple calls now, once I get past the agent telling me I've got a very fast connection and they can't see an issue or find open jobs, when they review previous notes there's a record somewhere to an order being placed, but no-one can find out what. It appears I'm now down as a new customer and something needs to be progressed by the "New IT" team, even though I've been with EE for over a year.
So, perhaps a Smart Hub Pro will be sent out, which will be good because it sounds like I'm entitled to one on my package.
However, I'm not convinced the hub itself is the issue, given that the Asus router performs similarly, except when a VPN is active.
Does anyone have any thoughts about what might be happening?
Thanks!
50 REPLIES 50
@QuantumPhys What was the outcome off your upload problem? Pictures need to be cleared for viewing!
@JimM11 - all the tests appeared OK, but with Teams or Zoom there are still issues with video/audio from my end. I can see and hear others ok but others have issues with the quality of my video and audio. I couldn't quite believe it until I recorded some calls and played them back.
I'm wondering if it might be some kind of Openreach routing issue because it goes away with a VPN, but I don't know how to investigate that, or even if I can ask someone to take a look.
@QuantumPhys How many times do i need to ask the same question. ""What was the outcome off your upload problem?""
 and have a look at this post that was replied earlier date and time stamped 07-05-2025 10:00 PM.
Hi @JimM11 , from the plots I've uploaded I can't see a specific uploade problem but I may not know how to interpret them, so any steer would be appreciated.
Looking back at the earlier reply, there's no Wifi booster on the network.
Tryfan_Tamer
Did you ever get this sorted?  I seem to be having the same issue.  I've moved from BT @ 500Mb to EE @ 900Mb & everyone is saying my Teams video/voice is really poor now.  I'm seeing a little bit of Network Jitter when looking at the stream but nothing obvious that would suggest any fault on my side.
I'm directly connected to the router which is a Smart Hub Plus.
I've used BT for the last 4 years with zero issues on Teams calls.
Sorry to hear you've got the same problem.
My Teams and Zoom issues were never resolved so in the end I left EE and am now with IDNet. Same ONT and no engineer visit required. Using my new router, I confirmed Teams and Zoom still weren't working on my last day with EE. Left the router connected overnight. The provider switched over at 3am and once I put in the new PPPoE login details I was back up and running again. Teams and Zoom immediately started working as they should.
aman961
I had the exact same issue with EE broadband when I first signed up and went through multiple trouble shooting steps.
I had numerous EE routers, upgraded the speed of my broadband etc..
Whenever I was on teams or zoom calls - the other party said my signal was terrible, constantly freezing and near enough impossible to work from home, but it was all good on my side.
I did end up getting this issue resolved by opting to obtain the BT smart hub 2 router, rather than the EE smart hub plus.
The issue revolves around the internal firewall the EE Smar hub plus router has - the only way to resolve is by using a different router. Potentially EE's Wifi 7 router would be a result, but to get something similar that doesn't cost a significant amount more per month you have 2 options:
- Buy your own router
- Obtain the BT smart hub 2 router
SFW8
I had the exactly same issue, along with my sky streaming.
I've never experienced this issue before until switching to EE.
Something isn't right.
TraderTravel
It's definitely worth raising this with EE Customer Service. Until more people complain, you won't get this resolved.
TMorphy
Hey QP,
I have actually same service and same issues with teams - so any upload of any images do render or sent.
if i tether my phone they upload straight away or use my office WIFI (which i admin and have with Zen)
Brought this up a while with EE and assumed they had issues with content filters.
Phoned them and asked them to remove all content and parent control for me to test
Also remove the wifi controls that appeared off on EE app - gaming and business QOS thing
So tried usual Wifi SSID and even creating guest SSID to use for work round.
My smart hub plus broke the other day with power plug issues,  so have its been replaced with same issue.
Done numerous factory resets and all that.     Ive given EE another phone just now and mentioned this thread.
I could just to install VPN or mess with DNS to get this working - but they should resolve this
Ideally, i would like to manage the router content with a  browser or CLI,  as the EE app for BB is hit and miss - probably using the same content issues
Thanks - i let you know,  hope i get on.
