Having trouble with my router
Profile closed
Not applicable
I am also betting this issue with my router, I have Smart hub pro and smart Wi-Fi Pro
Configured DDNS when i initially setup the new Smart Hub Pro and it was working fine, updated overnight to firmware version r2.64.3-R-1213091-PROD-1 and now DDNS sits at connecting constantly and doesnt update. Anyone else experiencing the same issue? Reset of router has made no difference.
Community Hero
Community Hero
@Profile closed Have not heard any different, so maybe one off the Pro user's also trying to use the feature will respond to you asked question.
Huggons1
When did you receive your Smart hub pro?
I believe the latest version is r2.64.7-R-1303938-PROD-1 App version: 2.34.2, so looks like you will be pulling through the update overnight very soon.
bobpullen
Star Contributor
Star Contributor
Ignoring the errant ‘connecting’ message, is the DDNS service actually working?
Sofaslug
Valued Contributor
Valued Contributor
I found the following brought through software updates...
Log out of ee app.
Delete app.
Reinstall app
Hard reset hub pro (via button)
Hard reset ONT (via button).
Good luck.
Log into app.
Reconnect hub to phone via ee app (scanning QR code).
At this stage you "might" see a message saying software updating or similar? I did.
mikefairgrieve
I thought the exact same as you however it is working, it only updates when the IP address changes (reboot etc) , latest firmware (r2.64.7-R-1303938-PROD-1 ) shows the exact same "Connecting" status but if you catch it on time once in a while you will see it shows "updating" etc. Its just not as frequent as the BT Hub was, which connected frequently whether the IP adress changed or not.
