Wifi signal disappeared/ Need remote reset
Khalid210
The Wi fi signal is completely disappeared and is now invisible to all my devices. After I changed a compatibility setting yesterday. My router light is still solid aqua, but I have no way to use an Ethernet cable to log in and fix it. So can you please reset my router's wifi configurations back to normal.
Northerner
Hi @Khalid210
Resert your router on the back, there should be a button which resets to the default settings and password.
Which router do you have.
Thanks for your help it just working
@Khalid210 Could have been when you enabled the Comp network the signals all dropped to re-establish the new network and your devices did not pick up the signals after that.
baron75mk3
Valued Contributor
Valued Contributor
Not sure which Router\Gateway you have but here are a few Pics to help you locate the factory reset pin.
Smart Hub 6 PlusSmart Hub 6 PlusSmart Hub 7 PlusSmart Hub 7 PlusSmart Hub 7 ProSmart Hub 7 Pro
Thanks it's working
