Eufy Doorbell
jenbird
I am having real difficulties setting up my Eufy Doorbell to the wi-fi it just wont connect? i have changed the setting in the management page to 2.4. I have re set the eufy but it says to turn off Firewall and I am unable to turn off Firewall in my hub?
25 REPLIES 25
Mustrum
@jenbird  Which router do you have and what model doorbell?
Please read out the model numbers as there are many models.
Maestro
Maestro
@jenbird And you do not ever want to turn of a firewall, is this a new doorbell that you are installing? You can go outside to the doorbell location with your mobile, and see if the wireless signal disappears from your mobile.
jenbird
Its a smart hub plus
Doorbell model is E304
Doorbell was purchased new from amazon, I have just spoken to EUFY and they have said you cant have FIREWALL on but there is no option to turn it off? I have the doorbell inside next to the hub and still wont connect
Mustrum
So what setting on 2.4 management page did you change?
Try switching the 5Ghz band off, WiFi 6 to 5 and WPA3 to 2.
Mustrum
Do you mean E340?
jenbird
yes sorry E340
Mustrum
So you marked this as solved, is Tha correct?
They're talking rubbish! The firewall there to protect you from remote attacks. Most users will have it on even if it can be disabled. My Ring Doorbell has no trouble operating alongside the firewall & is able to send video to Ring & get it back. So is this Eufy worse than a Ring?
i also had no problem with RING until it stopped working after 2 years, then went on reviews and got EUFY…
