My phone won't connect to the wifi
Anshin
Brilliant Contributor
@Anshin Multiple devices are ok, so the problem is your phone, either tell the phone to forget the connection completely, switch the phone off after you have don it, leave it few minutes, back on and reconnect to the wi-fi after that!
Northerner
Hi @Anshin
What device.
Are you connecting to the correct network and using the correct password.
Anshin
I have a similar problem.  My Android phone won't connect to the EE broadband,  with wrong password error.  I can connect via my EE account,  but this requires putting in my username and password every time. I've tried all the resetting solutions etc. But to no avail.
P.S. it used to work and other  devices connect ok.
