11-07-2025 06:57 PM
I have recently purchased a Eufy E340 video doorbell, but can't seem to connect it to my Smart Hub SH32B.
I've tried connecting to the 2.4Ghz Wi-Fi, but it still won't connect.
Has anyone else had the same problem, and have a solution?
12-07-2025 08:37 AM - edited 12-07-2025 08:38 AM
@tjturpin
Can you try deleting the the Eufy app on your phone and re-download it from App store,
Then log back in > reset doorbell > add new ?
Ali
11-07-2025 07:14 PM
11-07-2025 07:45 PM
Hi Chris_B
Yes, my phone (Apple iPhone) is connected to the 2.4Ghz, but it still doesn't connect, I also have a wi-fi extender which is on the 2.4Ghz and it doesn't connect to that either. Not sure what else to try
thanks
11-07-2025 08:27 PM
@tjturpin : Try setting up Compatible WiFi on the router under Advanced > Wireless Settings & connect your device to that.
11-07-2025 08:39 PM
hi XraySpeX
thank you for your reply.
I've already tried that method as well, but with no success
@tjturpin
Ali
12-07-2025 10:24 AM
Hi Ali_A
That worked!
How strange.
Thank you for your help
12-07-2025 10:28 AM
That's great @tjturpin
Glad it worked for you and you're up and running again.
Thanks for getting back to me and keeping me updated with this!
Ali
11-10-2025 08:52 AM
Sex video want to watch
11-10-2025 09:44 AM
@Tesfayebesufeka Read THIS
