18-02-2019 12:52 PM
I have just received a new EE Smarthub to replace the Brightbox I was previously using for my Broadband wireless internet connection.
I have set up the Smarthu, the light on the front is aqua. I can connect my mobile phone to the wireless connection no problem by using the password on the back of the hub.
However, when I try to connect my laptop by clicking on the available connection in the wireless network connection box , I get a message 'The network requires a network key (also called a wep key or wpa key). There are then two boxes, one for network key then another for confirm network key. I have tried putting in the same password which is on the back of the hub, but it won't connect.
The laptop was previously connected to the old Brightbox, but I can't remember whether I had this problem connecting to that. The laptop is an old Dell Latitude running on Windows XP.
What is this wep/wpa key I need to connect? I have tried another newer laptop running windows 7 home premium and this connects ok by just typing in the password on bak of hub, it's just this older laptop I am having problems with, yet it connected to the Brightbox.
Any help appreciated
18-02-2019 01:19 PM
What spec is the wireless on the old Dell? The 802.11x ?
All these "keys" are what you know as a password.
18-02-2019 01:42 PM
@XRaySpeX wrote:What spec is the wireless on the old Dell? The 802.11x ?
How do I find this info, please?
Yes, I thought that but I have tried putting the password in 50 times but it won't have it.
18-02-2019 01:46 PM
I would also like to add, I have tried to connect the laptop to a talk talk wireless network and I get the same problem, won't accept that password either.
The laptop works ok using an ethernet cable. It's obviously something to do with the laptop
18-02-2019 01:53 PM - edited 18-02-2019 01:56 PM
Look up the spec of your lappy, or its wireless adapter, in the docs you got with it or online.
It's possible its wireless adapter is faulty if it's failing with a TT router, but OTOH it works with your BB1.
18-02-2019 02:08 PM
@XRaySpeX wrote:Look up the spec of your lappy, or its wireless adapter, in the docs you got with it or online.
Not sure where the docs are, not sure what to look for online
It was working ok with the brightbox though? Not sure what TT router, OTOH, or BB1 means
18-02-2019 02:23 PM
Ok I get it, on the other hand, brightbox1, yes, that's what I thought. Is there a difference between BB1 and smarthub?
18-02-2019 02:25 PM
TT = TalkTalk.
OTOH = On the other hand.
BB1 - Brightbox 1
Feed the exact model of your Dell lappy + "Spec" into a search engine.
Go to Control Panel\Network and Internet\Network Connections on the lappy & R click the WiFi adapter & select Properties. What device name does it say under "Connect Using"?
18-02-2019 02:45 PM
@XRaySpeX wrote:TT = TalkTalk.
BB1 - Brightbox 1
Intel(R) PRO/Wireless LAN 2100 3A Mini PCI Adapter - device status: this device is working properly.
18-02-2019 02:47 PM
Communications
 Wireless Protocol802.11b Wired ProtocolGigabit Ethernet
