BB speed very low
karis6197
Over the last year or so, I've upgraded from 150 Mb/s to 500 & then to 1000 last month in an attempt to maintain satisfactory BB speed in, what I assume to be, periods of high system load. I've been testing every day for the last moth & speed frequently drops below 500 & yesterday it was down to 150. Today it's ridiculous 60Mb/s which I don't consider as acceptable, can I claim under the EE guaranteed speed delivery?
Mustrum
@karis6197   have you reported these issues to EE?
They can't do anything unless you tell them.
Have you looked at the info on the Speed Guarentee Help pages or followed the steps on it? https://ee.co.uk/help/broadband/manage-use/ee-speed-guarantee
Need to know
Speed guarantee
Your broadband comes with your own personal speed guarantee, which guarantees the speed to your hub.
You can check your speed using the steps above. If it's not what we promised, let us know.
17 REPLIES 17
Maestro
Maestro
@karis6197 You could try but you need to look at what the contract say's and see also the response from EE when you approach them! Speed will always go up and down it's the nature off the connection when it leaves your hub. Linked below about the speeds from EE.
EE Broadband and Speed Guarantee | Broadband Help | EE
@karis6197 Been a while since i lasted replied to you so took the look back on your posting's, are you still using the BT Smarthub2 as your main device, been a few upgrades over the last couple year's to it. and the EE App should be somewhat workable with it, the fast.com speed test that the app use's in the test structure may if working give you an idea, dual hit with the newer hub's in that there is a speed test and display to the Hub, then a secondary speed test to the actual testing device. Chasing the speed is not the best, just did a quick one and although only FF500 myself and NO longer with EE, linked below the test result for you.
https://www.speedtest.net/result/19011892707
Mustrum
Need to know
Speed guarantee
karis6197
Working on it but it's a PITA, but why do I have to make all the running! It all starts off very well when I upgrade & then speed often randomly drops, to what I consider, unacceptable levels compared to contract. Sometimes it's for only a short period of time & it mostly all still works but it's not what I'm paying for & I often have to reset a lot of my wifi connected devices! My latest package includes the new EE 7 hub, which I expected when I upgraded to 500 a while ago, but I was sent an older BT hub instead! I factory reset my old 500 BT hub to start from scratch again & it worked fine for a week or so but then my speed just started to get throttled back again! I upgraded to 1000 but, sadly after couple of weeks I'm getting throttled back again, although my measured speed is higher!
This is a recurring problem that I've experienced throughout the whole fibre BB speed range packages since I got fibre where I live. It all starts off very well but, after being lured into a sense of security, my actual BB speed seems to get throttled back, presumably when there are local network problems! - today the most I could get was 150. I check my BB speed very regularly but how many others do? I suspect they just carry on in oblivious, ignorant bliss! As I have an old employment history, I've always stuck with BT & now EE as they own the infrastructure through (BT) Openreach but I'm beginning to think I'm being conned! Call it conspiracy theory if you like but I'm old enough & have enough experience to know what BRAS meant when connected to the old copper cable network. I thought those problems had disappeared with fibre, can anyone on here categorically tell me I've got it all wrong?
@karis6197 Are you still on and using the old BT Smarthub2 for the connection? If so are you able to go look at the web manager interface on it, and if so in the advanced logging how many pages of information does it have?
http://192.168.1.254 to get to it. Speedtest.net but the app is way better in testing as it pushes a lot off data down through the connection, the web version gives a little more detail but not as much data throughput. Think my sample above is web will go look and confirm for you. YES for sure is the web version, so will do the windows app and link it below. Linked the app windows installed version and to a different server so you can see.
https://www.speedtest.net/my-result/d/ee925bf4-5237-4b12-a3c5-5f54ca2fefd6
From Openreach as below to help you.
1. FTTP is a contended service, up to 32 users can be sharing the 2.5Gb backhaul, so you can never expect the full speed all the time, you may get 900mb when there are fewer people using it. I expect that you are sharing the backhaul with many users. If everyone was using it fully, you may only get 78mbs. Its called statistical multiplexing, which relies on the fact that all users are not utilising their connection fully, all of the time.
BT quote up to 900mb, so you are likely to get much less than that during peak times.
Speed tests pass very little data, so normally give a much higher speed.
2. The max OR connect to a splitter is 30 ( 32 is the splitter maximum but policy is 30 ) not every CBT port provided is likely to have a customer using it , so unless on a ‘new site’ that has no alternatives to OR FTTP the actual number on a splitter is likely to be way less , OR currently have about a 30% take up, so maybe 10 users per splitter , plus the majority don’t take 900Mb but slower profiles , and the chances of those ‘on line ‘ at any one time all and doing something intensive, rather than browsing / Netflix that may be consuming less than 30-100Mb , is slim , that’s why there is a 700Mb minimum speed guarantee on 900Mb …..the 2.4Gb will be plenty ,you would have to be incredibly unlucky to have any consistent congestion.
If you suspect PON congestion, try at a time when there won’t be much activity, late evening or early morning .
Although you have tried somethings to ‘ isolate’ the problem , the most obvious thing to do ( that you haven’t apparently tried ) is use the BT router , without doing that , you haven’t really proved anything , your third party router may great , but even great routers can be mis configured or faulty
Mustrum
@karis6197   without knowing what you have done I can't say you have it wrong.
Are you checking the speeds as described in the Speed Guarantee Help page?
Are you sure none of your connected devices is uploading to the internet whilst you do your speed tests?
And as before, have you reported your issues to EE?
This is not Customer Services, n one has account access or knows who you are or what services you have.,
karis6197
No I’m not using an old BT Smart Hub 2, that’s been returned to BT/EE to avoid the £65 surcharge! As stated in my post, I’m using a brand new EE 7 router, not a 3rd party offering, I also use Speedtest.net by Ookla, which I’ve been using for many years. I’m not in the same knowledge sphere as you are as my experience is mainly from an original employment base (the old Post Office) & experience gained some years ago successfully dealing with BT over problems at a previous rural property connected to a copper network. This was eventually rectified/cured after several years complaining when BT replaced all the connections in their splitter box up a nearby telegraph pole! Being an Engineer, I’m interested in how it all works but no longer have the time or interest in learning how to understand the complexities of the modern fibre network, I just want it to work properly!
Easter is over; my speed this morning is back up to around 600 so I’m definitely being automatically & sometimes severely throttled (sometimes 80%!) during peak traffic times; operationally sort of OK but still not the service I’m paying for but if customers don’t check, hopefully no one will notice! My next step is to continue collating speed test data & complain to EE but this in itself seems a major challenge getting anyone to take interest these days!
@karis6197 Are you using anything else with the EE Hub 7 Plus/Pro that you have now, either an extender from EE or a separate third party one, it all matters in the scope off the network.
Speed external can go up/down all depending on the external factors. ie i have FF500 connection and 95% off the time it's spot on when testing, but the lowest sustained has been just over 200Mb/s and the EXTERNAL side was just so busy, normal running i have estimated in the home depending on what is going on at just over the 100Mb/s, so covered all the bases as speed to that. Do NOT use any ISP equipment at all, fully Asus Ai Mesh with a little Powerline thrown in the mix, but FULLY trust all of my wireless connections that could/can cause issues from time/time. Just had to sort out my Samsung A54 mobile, down/up was 17/70Mb/s when it played up and Wireless off/on was the only way to restore it speed wise, issue was POOR wireless wifi signal and a new AP purchased/installed sorted it out, would have swore blind not an issue and took a few weeks to work it out what was going on, NEVER done it again since the addition. See the Samsung speed test linked below.
https://www.speedtest.net/my-result/d/d76907e3-8159-4cda-bed2-d8b6ab17277f
With the issue above, and slightly before time working well below it.
https://www.speedtest.net/my-result/d/d035be2a-a905-404b-a05e-ba27da4a4f90
karis6197
I know & understand speed will vary, depending on local network use/congestion, but the speed drop here is so severe sometimes; it was less than 100 on Good Friday & I don't consider this contractually acceptable. I never experienced such severe  speed variation in our previous property which was only 50 mb/s from a "fibre to a cabinet" connection 300m down the road ! We now live in a different area with a recently (Openreach) installed full fibre connection to the property which I expected  to be so much better & more stable. It's a bungalow with a largish footprint & the EE router is right at the front so I do have a couple of TP Link, 650 extenders at the back of the property. I've have been using these for some years at a previous rural property to connect a garden room. They now power a Nest thermostat, 2 x internet connected TV's (via EE mini boxes) & 3 x Ring security cameras in our back garden, these all have a good signal at around 50 RSSI or less. We also have a Sonos radio system, a further 4 Ring security cameras & 2 more Smart TV's, at the front of the property all connecting through the main router but the TV's are never all connected at the same time. As you can see, I am a bit of a "techy" & do like my wifi/internet gadgets but it all generally works very well. I do sometimes have problems with devices auto reconnecting after EE "helpfully" resets my hub connection overnight - or when they throttle my internet speed! The laptop I use to test speed is only 2m from the main EE hub but when I simultaneously check speed using my phone, there is virtually no difference, even at the back of the property.
