Amazon echo not syncing
Pete155
Amazon echo gen 1.
We have just gone onto we fibre from bt. I can't get my Amazon echo first generation to connect. It lights up orange as it it's trying to sync but won't!!!  Any ideas please?
EE engineer said its a faulty router so sent a new one. Still have the same problem, even changed router to 2.4 mgz but no joy.
Thanks in advance
Pete
Try on the Advanced > Wireless Settings page to temporarily disable the 5 GHz WiFi band & move off the Smart channel while connecting problematic 2.4 GHz devices.
