XBox problems amongst others
Gibsonsandroid
I have SMART HUB 7 PRO and WIFI EXTENDER 7 PRO
Main modem (HUB 7)
Ethernet Xbox Series S(Son) Zero
Wifi Secondary Box (EXTENDER 7)
Ethernet Switch 2 Good 95% Usually works after reset of router if needed, though often falls back to Wifi from ethernet.
Ethernet Xbox Series S(Dad) Zero
Wifi Network
Hisense Roku TVStable (until last week or so) then occasional drops usually works after reset of router
  3 MOTOMobiles 2 -50% usable in the last 8 weeks ,1 -unstable since install
Amazon Fire TabletSeemingly stable rarely used
Chromebook (Noah)Seemingly stable rarely used
Chromebook (Phoebe) Seemingly stable rarely used
Chromebook (Tim)Stable
Mac Mini Usable 20% Usable, though has been unused until last 6 weeks
  Switch 1 Seemingly stable rarely used
Switch liteSeemingly stable rarely used
Xbox OneZero
Hp PrinterRarely used, always needs a restart of router to use
Recently tried an Apple TV and worked for about 5 mins, couldn’t use it after.
Disconnected for simplicity several Tapo smart plug sockets, Amazon Echo devices and chinese brand smart bulbs. Haven’t even tried setting them up.
At installation everything was fine. At some point between Xmas and NY I have not been able to use any Xbox product on my network
At the same time the secondary wifi box also lost connection to the main router. This began working by itself several weeks later, but Wifi signal was not hugely different so lived with it.
The Xboxes will not connect at all via ipv6 or ipv4, though seem to do so now and again in the background as they seem to pick up little bits like fragments of the desktop tiles in the background. One sign is for example Fortnite and Rocket Leagues title tiles that change every 10 days or so seem to stay largely up to date. At one point after many reboots and recycles and tweaks (not sure how) I got them working for about a week, then nothing again. The Xbox cannot resolve a NAT type, sometimes will give a message about DHCP though usually doesn’t get that far. XBox support is full of dead links and circular solutions, though it has mentioned ensuring Teredo settings are correct, but i cannot find them on the router.
https://support.xbox.com/en-US/help/hardware-network/connect-network/network-ports-used-xbox-live
This link highlights opening ports but the router will only allow me to open one port.With the xbox so popular why are all theses ports not selectable in a block or open by default.
Even interfacing with the modem via the app or directly with 192.168.1.254 is unstable, either regularly losing the signal or crashing the page. (accessed via phone and chromebook for reference). The EE app regularly reports a device online when it isn’t even in the house or is switched off (properly off not in sleep).
The Hisense Roku TV smart TV has always had a robust connection even when the rest of the network can seem slow at times, still giving 4K steaming over WIFI.
The switch 2 indicates it is connected to via Wifi or ethernet and switches brtween the 2 despite being connected to the ethernet to the secondary box, but remains working most of the time.
Internet speeds tend to be fast if there is a connection but it is a case of if it gets through.
The Mac is unusable, when it is working it is fast then just stops for hours at a time. I may be crazy but it seems Youtube seems to be more robust than anything else, continuing to play even when everything else is spinning wheels.
We have poor signal in my daughters room, i was told in branch (Bath) that this was whole house broadband, I am generally pleased with Wifi signal everywhere else and 4K own the TV while others are using the network, even when the repeater wasn’t working is good enough for me.
Help me Forza Horizon is out next month.
Leanne_T
Morning @Gibsonsandroid
This is going to need to be investigated further to see what could be causing this for you. To do this I would suggest getting in touch with our broadband tech guides, they can run troubleshooting with you and see if they can help you get this resolved.
Please let us know how you get on.
7 REPLIES 7
Leanne_T
Rhardy2026
Hi did you manage to get to the bottom of this issue as im a new EE customer and seem be having the same issue with my kids Xbox’s
Leanne_T
Hi @Rhardy2026
Thanks for coming here.
Does the Xbox not connect to the router? Or is the connection lost whilst gaming? Which router are you using?
Also, are connected via ethernet?
Hi I’m also having issues with the ee smart hub 7 broadband it’s connected to my Xbox and it’s saying my Xbox is getting 5.0GHz but I’m having issues playing multiplayer games with constant lag and packet loss making games unable and this isn’t the first time I’ve had issues with ee WiFi
Christopher_G
Hi @PigeonPG
Welcome to the community.
I recommend speaking with our technical support team so they can run through some diagnostic tests to try and help with this problem.
Let us know how you get on please.
Gibsonsandroid
Problem was fine for a few months and now is worse than ever. looked at the port forwarding, but now intermittently on top of previous issues, my network keeps activating and deactivating IP6 which means not only are my xboxes now almost unusable online, but a NordVPN on my Chromebook to watch formula 1 only works 50" of the time and the switches play up. Just got to wait till august till out of contract and bye bye EE. Anyone know of a BB supplier that buys out contracts for switch like Vodafone do on mobiles.
