close
wrong amount of data recieved
skimbob
I've just moved to a sim only plan that should be 120 gb but it's only showing 80 gb. Any ideas why?
@skimbob   If you look at add ons do you see the extra data as a add on ?  If you do it’s because your tariff is a 80Gb tariff but you also receive a free data add on.   EE don’t change the name of the original tariff if you receive a add on also.
