speeds have dropped and stayed low for months
Tom_HB
Hello,
Since moving into our new home in oct 2020 we have constantly had issues with our internet (very unlucky!).
From "mid oct - end of nov" we had a great internet connection and were getting around 70mbps which is expected from our package.
Then from "Dec - start of Feb" we had no internet at all due to a fault that took way longer than it should have for openreach to solve.
Since then our speeds dropped to around 50mbps, which was ok but then in april - may the internet only held a connection for 2hrs at a time, then the router had to be factory reset every time for it to work. At this point, the internet also dropped even lower to 16mbps at one point!
Finally, since this last issue was fixed in may, our speeds have gone all the way down to 30mbps and haven't improved at all.
So all I'm asking is, what can I do? On the EE status page the downstream sync rate has been put to 35mbps for months and no amount of uninterrupted up time has improved our connection speeds.
Thanks, Tom
11 REPLIES 11
Insist on holding EE to its "Guaranteed Min. D/Load Speed" to be found in your MyEE for BB under "Your BB speed".
At the moment it seems that's the best we can do and just hope for the best.
we have called them again this week and have told them about how our speeds are less then half our rate and are below the 43mbps minimum promise. So far they were holding out on the mso notice but thats been on our record since jan.
I really hope this time it gets sorted, whatever the actual issue may be.
I was hoping that by posting on here, maybe there would be a clear issue with all the data and numbers provided but I guess the issue lies somewhere else (unfortunately for me).
Thanks for the help and advice guys.
