close
re- set password on 4gee mini
shailer
How do i go about re setting our password on our 4gee mini? TIA
Which pwd? Admin or WiFi?
hi thanks for reply its for wifi password as wanting to connect tv we are having fitted in camper van but can't remember password we set
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then on the WiFi Settings tab you should be able to see your WiFi password in clear & change it if you like.
