close
power cable for 4G mobile broadband
LeilaZ
Does anyone know where to get a power cable for EE 4G mobile broadband? Mine is not working.
Many thanks.
7 REPLIES 7
Christopher_G
Hi @LeilaZ
Welcome to the community.
Which 4G router do you have and how long have you had it?
Hi Chris,
From May/2021, so 4 months.
Christopher_G
OK thanks, @LeilaZ
What's happened with the charger? Is it just not working at all?
After unplugging it from the router, it stopped working. I have tried using a similar charger (from a small hoover) , however it couldn't sustain power, thought must be the power cable's problem.
Christopher_G
Which router do you have, @LeilaZ?
If you're not sure, post a photo of it and we'll try and help. 🙂
Christopher_G
Thanks @LeilaZ
I'd recommend speaking to our Technical Support team who'll be able to run through some options with you.
