close
brightbox 2 router keeps dropping out and have to reset
Sangs
My brightbox2 router system log states possible DoS attacks and I keep having to switch router on and off
Just to finish off, there was a fault on the line which BT have repaired and the BT engineer is going to recommend a new router due to the age of my Brightbox 2 and the fact that it appears to be overheating. Thank you all for your advice.
18 REPLIES 18
Mustrum
@Sangs  are they causing you any issues?
If not, just ignore them, the router firewall will be doing its job and stopping them getting through.
Is it the BB as a whole dropping or just the WiFi connections? What colours are the light sequence when it happens?
  • For a BrightBox: login and go to Advanced Settings/ System/ DSL Status. Also post 'System Uptime' from top of System Log page.
  • For a SmartHub: login and go to Advanced Settings/ Technical Log/ Information. Obscure your names & any numbers in the BB Username & also the SSIDs.
The green lights are all on but no internet access is available on our phones or PC or Smart Tvs. I then have to switch the router off and then on again to regain internet access. I thought I may have a faulty router but then looking at the system logs see the message about DoS, although they may be a red herring. Hope you can be of help.
The info you require is:-
System Uptime is: 18:18:36
Current Time/Date is: 14:36:35 20 May
14:36:16, 20 May. admin login success from 192.168.1.116
14:30:33, 20 May. Device connected: 192.168.1.116, a8:5e:45:17:e6:d8, DESKTOP-J2F5T5K, lease time is 172800 seconds
14:29:21, 20 May. Device connected: 192.168.1.201, c6:cc:e7:35:e3:62, Unknown Device, lease time is 172800 seconds
14:06:21, 20 May. Device connected: 192.168.1.244, 1c:12:b0:7d:8f:d6, amazon-df0013e9b, lease time is 172800 seconds
13:40:39, 20 May. Time is synced to NTP server
13:33:58, 20 May. Possible DoS attack detected from 87.237.17.201
13:33:48, 20 May. Possible DoS attack detected from 87.237.17.169
12:40:21, 20 May. Time is synced to NTP server
11:40:04, 20 May. Time is synced to NTP server
11:27:19, 20 May. admin timeout from 192.168.1.116
11:27:19, 20 May. admin logout from 192.168.1.116
11:23:28, 20 May. admin login success from 192.168.1.116
10:39:45, 20 May. Time is synced to NTP server
10:13:07, 20 May. Device connected: 192.168.1.116, a8:5e:45:17:e6:d8, DESKTOP-J2F5T5K, lease time is 172800 seconds
09:55:32, 20 May. Possible DoS attack detected from 184.105.139.81
09:43:06, 20 May. Possible DoS attack detected from 122.228.19.80
09:39:28, 20 May. Time is synced to NTP server
08:56:25, 20 May. Device connected: 192.168.1.201, c6:cc:e7:35:e3:62, Unknown Device, lease time is 172800 seconds
08:39:11, 20 May. Time is synced to NTP server
07:38:55, 20 May. Time is synced to NTP server
07:23:55, 20 May. Device connected: 192.168.1.96, f4:fe:fb:23:4c:39, Samsung, lease time is 172800 seconds
06:38:38, 20 May. Time is synced to NTP server
05:38:22, 20 May. Time is synced to NTP server
04:38:06, 20 May. Time is synced to NTP server
03:57:01, 20 May. Device connected: 192.168.1.96, f4:fe:fb:23:4c:39, Samsung, lease time is 172800 seconds
03:37:50, 20 May. Time is synced to NTP server
03:30:29, 20 May. Possible DoS attack detected from 194.165.16.14
02:37:34, 20 May. Time is synced to NTP server
01:45:41, 20 May. Device connected: 192.168.1.96, f4:fe:fb:23:4c:39, Samsung, lease time is 172800 seconds
01:45:40, 20 May. Device connected: 192.168.1.89, 70:2a:d5:8f:9d:b1, Samsung, lease time is 172800 seconds
01:39:15, 20 May. Possible DoS attack detected from 146.88.240.4
01:37:45, 20 May. Possible DoS attack detected from 194.165.16.10
01:37:17, 20 May. Time is synced to NTP server
00:37:01, 20 May. Time is synced to NTP server
00:36:48, 20 May. PPP connection up (FIBRE)
00:36:48, 20 May. PPP: IPCP up
00:36:47, 20 May. PPP: CHAP authentication succeeded
00:36:47, 20 May. PPP: LCP up
00:36:47, 20 May. PPP: Received PADS
00:36:47, 20 May. PPP: Sending PADR
00:36:47, 20 May. PPP: Received PADO
00:36:47, 20 May. PPP: Sending PADI
00:36:42, 20 May. PPP: Sending PADI
00:36:37, 20 May. PPP: Sending PADI
00:36:32, 20 May. PPP: Sending PADI
00:36:27, 20 May. PPP: Sending PADI
00:36:22, 20 May. PPP: Sending PADI
00:36:17, 20 May. PPP: Sending PADI
00:36:17, 20 May. PPP: Starting PPP daemon
00:36:16, 20 May. WAN link up (FIBRE)
00:36:04, 20 May. WAN link down (FIBRE)
00:36:03, 20 May. PPP connection down (FIBRE)
00:35:52, 20 May. PPP: Stopped PPP daemon(0,1,5)
00:35:46, 20 May. PPP: IPCP down
00:35:46, 20 May. PPP: LCP down
00:20:54, 20 May. Time is synced to NTP server
23:59:58, 19 May. Device connected: 192.168.1.89, 70:2a:d5:8f:9d:b1, Samsung, lease time is 172800 seconds
23:55:45, 19 May. Possible DoS attack detected from 122.228.19.80
23:55:27, 19 May. Device connected: 192.168.1.89, 70:2a:d5:8f:9d:b1, Samsung, lease time is 172800 seconds
23:55:26, 19 May. Device connected: 192.168.1.96, f4:fe:fb:23:4c:39, Samsung, lease time is 172800 seconds
23:52:23, 19 May. Possible DoS attack detected from 219.147.112.250
23:40:58, 19 May. Possible DoS attack detected from 194.165.16.14
23:32:25, 19 May. Possible DoS attack detected from 194.165.16.10
23:20:37, 19 May. Time is synced to NTP server
22:20:20, 19 May. Time is synced to NTP server
22:06:28, 19 May. Device connected: 192.168.1.116, a8:5e:45:17:e6:d8, DESKTOP-J2F5T5K, lease time is 172800 seconds
22:03:18, 19 May. Possible DoS attack detected from 89.248.165.97
22:03:08, 19 May. Possible DoS attack detected from 89.248.165.97
22:02:57, 19 May. Possible DoS attack detected from 89.248.165.97
22:02:47, 19 May. Possible DoS attack detected from 89.248.165.97
22:02:44, 19 May. Device connected: 192.168.1.201, c6:cc:e7:35:e3:62, Unknown Device, lease time is 172800 seconds
22:02:37, 19 May. Possible DoS attack detected from 89.248.165.97
22:02:27, 19 May. Possible DoS attack det
22:02:27, 19 May. Possible DoS attack detected from 89.248.165.97
22:02:17, 19 May. Possible DoS attack detected from 89.248.165.97
21:20:03, 19 May. Time is synced to NTP server
20:44:59, 19 May. Device connected: 192.168.1.96, f4:fe:fb:23:4c:39, Samsung, lease time is 172800 seconds
20:40:33, 19 May. admin logout from 192.168.1.116
20:29:42, 19 May. admin login success from 192.168.1.116
20:23:50, 19 May. Device connected: 192.168.1.116, a8:5e:45:17:e6:d8, DESKTOP-J2F5T5K, lease time is 172800 seconds
20:23:48, 19 May. Device connected: 192.168.1.31, b4:7c:9c:6f:99:39, amazon-d5593538f, lease time is 172800 seconds
20:21:54, 19 May. Device connected: 192.168.1.191, cc:61:e5:cf:0f:5e, android-9198d4a0bc52e069, lease time is 172800 seconds
20:20:57, 19 May. Device connected: 192.168.1.201, c6:cc:e7:35:e3:62, Unknown Device, lease time is 172800 seconds
20:20:07, 19 May. Device connected: 192.168.1.31, b4:7c:9c:6f:99:39, amazon-d5593538f, lease time is 172800 seconds
20:19:49, 19 May. Device connected: 192.168.1.244, 1c:12:b0:7d:8f:d6, amazon-df0013e9b, lease time is 172800 seconds
20:19:47, 19 May. Time is synced to NTP server
20:19:44, 19 May. Device connected: 192.168.1.191, cc:61:e5:cf:0f:5e, android-9198d4a0bc52e069, lease time is 172800 seconds
20:19:33, 19 May. PPP connection up (FIBRE)
20:19:33, 19 May. PPP: IPCP up
20:19:32, 19 May. PPP: CHAP authentication succeeded
20:19:32, 19 May. PPP: LCP up
20:19:32, 19 May. PPP: Received PADS
20:19:32, 19 May. PPP: Sending PADR
20:19:32, 19 May. PPP: Received PADO
20:19:32, 19 May. PPP: Sending PADI
20:19:27, 19 May. PPP: Sending PADI
20:19:22, 19 May. PPP: Sending PADI
20:19:17, 19 May. PPP: Sending PADI
20:19:12, 19 May. PPP: Sending PADI
20:19:12, 19 May. PPP: Starting PPP daemon
20:19:09, 19 May. WAN link up (FIBRE)
20:19:06, 19 May. System up, firmware version: v0.06.00.0001-OT (Tue May 19 15:34:07 2020)
20:18:24, 19 May. System start
00:21:47, 01 Jan. Device connected: 192.168.1.79, 00:bb:3a:a3:a9:9e, Unknown Device, lease time is 172800 seconds
00:21:36, 01 Jan. Device connected: 192.168.1.79, 00:bb:3a:a3:a9:9e, Unknown Device, lease time is 172800 seconds
00:21:25, 01 Jan. Device connected: 192.168.1.79, 00:bb:3a:a3:a9:9e, Unknown Device, lease time is 172800 seconds
00:21:14, 01 Jan. Device connected: 192.168.1.79, 00:bb:3a:a3:a9:9e, Unknown Device, lease time is 172800 seconds
00:21:04, 01 Jan. Device connected: 192.168.1.79, 00:bb:3a:a3:a9:9e, Unknown Device, lease time is 172800 seconds
00:20:53, 01 Jan. Device connected: 192.168.1.79, 00:bb:3a:a3:a9:9e, Unknown Device, lease time is 172800 seconds
00:02:14, 01 Jan. Device connected: 192.168.1.201, c6:cc:e7:35:e3:62, Unknown Device, lease time is 172800 seconds
00:02:03, 01 Jan. Device connected: 192.168.1.31, b4:7c:9c:6f:99:39, amazon-d5593538f, lease time is 172800 seconds
00:01:46, 01 Jan. Device connected: 192.168.1.191, cc:61:e5:cf:0f:5e, android-9198d4a0bc52e069, lease time is 172800 seconds
00:01:17, 01 Jan. Device connected: 192.168.1.89, 70:2a:d5:8f:9d:b1, Samsung, lease time is 172800 seconds
00:01:15, 01 Jan. Device connected: 192.168.1.244, 1c:12:b0:7d:8f:d6, amazon-df0013e9b, lease time is 172800 seconds
00:01:07, 01 Jan. System up, firmware version: v0.06.00.0001-OT (Tue May 19 15:34:07 2020)
00:00:26, 01 Jan. System start
19:09:58, 19 May. WAN link down (FIBRE)
19:09:57, 19 May. PPP connection down (FIBRE)
19:09:47, 19 May. PPP: Stopped PPP daemon(0,1,5)
19:09:41, 19 May. PPP: IPCP down
19:09:41, 19 May. PPP: LCP down
no issues with the Dos messages, but the router drops out despite all the lights being green, I then have to reboot the router.
Sorry, that's not the info I requested. The System Log is of no use.
Is this what you mean?
System Uptime is: 19:18:28 Current Time/Date is: 15:36:26 20 MaySystem Uptime is: 19:18:28 Current Time/Date is: 15:36:26 20 May
Mustrum
@Sangs  you need to wait for a mod to approve the pics before they can be seen.
Yes, thanks, that's 1 out of 3. I'll await the rest.
