close
Wifi connection to my phone keeps dropping
JasonR7
I just switched from Sky broadband to EE. It works fine for my personal laptop, work laptop, and streaming to my TV, but for some reason it keeps dropping out with my phone. Sometimes the wifi connection completely drops, and sometimes the internet is very slow despite being connected to the wifi (this is at the same time as I'm using the internet fine on a different device).
Never had this problem with Sky and it's not my phone (which works on wifi fine elsewhere anyway) so I'm assuming it's the EE router. What is going on?
11 REPLIES 11
Which router? Which model phone?
Hi, it's a Brightbox 1(R) according to the box. Phone is a Sony Xperia XZ1 compact.
Thanks.
Ah, OK, not what I thought it might be to which I do have a solution.
So, you have standard ADSL BB?
Yep, standard old broadband
Christopher_G
Hi @JasonR7
Welcome to the community.
Have you spoken to our technical support team? They'll be able to run through some troubleshooting with you and make sure everything's OK from our side.
How do I contact tech support? (your link just sends me to my Private Messages inbox)
And how is it different to this?
Call CS on the Freephone no. in my sig.
This is a user discussion forum; that is CS.
AlexToleman
Hi, I have this exact same problem and have done for a long time now, i have tried boosters and extenders but they dont work. The wifi works fine on laptop, Oculus quest2, amazon fire stick and other devices but not on mobile phones. My sons have iphones, my wife and i both have Samsungs and all 4 of them have the same issue where the internet drops or lags, never on any other device.
Do i need a new router? what do i need to do??? thanks
James_B
EE Community Manager
Hi @AlexToleman,
Which router do you have? Do the phone's only drop the connection when they are far away from the router?
