10-11-2021
08:01 PM
- last edited on
14-11-2021
07:33 PM
MikeT
I don’t know if I am connected to my Bt broadband full fibre for WiFi calling, my works phone shows a WiFi calling banner on the top left of the screen
10-11-2021 08:42 PM - edited 10-11-2021 08:44 PM
I guess the phone is not choosing the WiFi calling option as it is detecting a mobile signal.
I did see a suggestion somewhere on here to get it to kick in switch the phone to Airplane mode, but not tried it myself,
Edit, seems that also switches WiFi off, so you then need to switch it back on.
10-11-2021 08:14 PM
I guess you figured it out?
10-11-2021 08:21 PM
No it’s still doesn’t show any WiFi calling banner which my works phone does
10-11-2021 08:23 PM
Then why have you crossed out the text in the OP?
10-11-2021 08:28 PM
I didn’t it did that when I was typing the question into the box so the issue still remains, maybe you could help
10-11-2021 08:30 PM
This issue hasn’t been solved irrespective of someone posting to the contrary
10-11-2021 08:30 PM
Ah OK.
On the phone WiFi settings does it show you are connected to your home broadband?
10-11-2021 08:32 PM
You are not having much luck with your typing this evening! You would be the only one whp cpu;d select the solved bit - perhaps you meant to click the thanks button?
10-11-2021 08:32 PM
I have a full WiFi signal showing on the Home Screen, WiFi calling enabled volte is off
10-11-2021 08:34 PM
And do you have full mobile signal as well?
