WiFi disc
Exematt
Valued Contributor
Valued Contributor
I have just got a new Smart hub, can I just add 1 disc and place it somewhere else in the house- or does the 1st disc need to stay connected by an Ethernet cable, and then get a second disc?
27 REPLIES 27
Leanne_T
Hi @Exematt
Which WiFi disc do you have?
Thanks 🙂
Leanne
Exematt
Valued Contributor
Valued Contributor
Hi
I have a white BT disc, and the white EE smart hub.
Matt
Leanne_T
Thanks @Exematt
I have asked our Broadband team and they have advised, these will work with the Smart Router but you will need to keep one disc connected to the router via Ethernet to broadcast internet from the router to the other discs.
Hope this helps.
Exematt
Valued Contributor
Valued Contributor
Does the 1st EE disc work disconnected  or are they the same?
Thanks for looking.
Leanne_T
Hi @Exematt
The EE Smart WiFi discs will only work with the EE Smart Router.
They will only require an ethernet connection as part of the initial setup, after this the disc can placed where you would like without an ethernet connection. The router can communicate directly with the disc.
Thanks 🙂
Exematt
Valued Contributor
Valued Contributor
So unlile the BT disc, I can have 1 wireless EE  disc??
Leanne_T
Hi @Exematt
You can view how the Smart WiFi works in the video on EE Smart WiFi Help page.
Thanks.
Exematt
Valued Contributor
Valued Contributor
So unlike the BT disc, I can have 1 wireless EE  disc??
Christopher_G
If you're using a BT Disc and an EE Disc, one of them would have to be connected through the ethernet cable, @Exematt.
If you're just using the EE discs, you can connect up to six wireless discs.
I just want to use 1 ee disc without an ethernet cable. Is this actually possible! Nobody seems definate!!
