close
Why does my speed vary so much anything from 1 Mbs to 43 Mbs I have a 4 G router
ggm01
Northerner
Hi @ggm01
Have you checked your local network for problems?
https://coverage.ee.co.uk/coverage/ee
Hi @ggm01
It sounds like you have no issues with your connection as-such, but just variable speed.
Unfortunately this is not, of itself, a fault - it is potentially just a symptom of varying amounts of use on the local network, manifesting itself as variable speeds.
Having said that, some of the speeds you've mentioned are below what I'd expect in most circumstances and the network status checker than @Northerner has suggested checking, would be an excellent place to start in this.
