close
Which mesh network is best for EE4G router?
Abeck
I’ve recently got the EE 4g WiFi router and it works well but there are black spots at the end of the house.  I’ve been looking to get a mesh network set up but some seem to be incompatible with the EE 4G router.  Do you know which ones work with it and are easy to set up?
James_B
EE Community Manager
Hi @Abeck,
Most mesh systems are designed to work with any router. The manufacturers should be able to confirm if there are any compatibility issues with mobile broadband.
Thanks James.  I was just wondering if anyone had set up a mesh system with 4g router and had an easy time doing it as most seem to need a work around.
James_B
Hi @Abeck,
Hopefully a community member with personal experience of setting up a mesh network with a 4G router will see this soon. 🙂
