When will the Oxygen OS 11 of OnePlus 7 PRO 5G be updated?
BGHH141
The 4G version of OnePlus 7 series has been updated with Android 11. When will 5G devices be updated?
James_B
EE Community Manager
Hi @BGHH141,
The manufacturer will push a notification to your phone as soon as they make the update available for your particular device.
Hey James,
The manufacturer stated explicitly that it's with EE to review and push the update. Equally it says the same on the EE community, e.g. here: https://community.ee.co.uk/t5/Blog/How-EE-works-to-test-smartphone-software-updates/ba-p/696855
Is there any plans from EE to support the phone for another upgrade?
Thanks for your response!
It doesn't look like we'll be getting the Android 11 update, poor show from EE when the 5g device on other networks have had it. OnePlus will soon be rolling out the Android 12 beta for the newer devices.
@Neil671  OnePlus create the software EE only have to approve it, so if there are issues with it Oneplus have to fix the issue and EE then have to approve that revision. Once approved Oneplus push it out.   If it’s not out then Oneplus still have issues with it.
