Re: Unlocked OnePlus 7 Pro 5G (GM1920) unable to use local upgrade feature
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
07-03-2021 12:42 PM
Hi,I also have OnePlus 7pro 5g gm1920 EU I am having issues with local update unable to find file in directory,able to upgrade ota,as updated from android 9 to android 10 now trying to update beta not allowing me to have you found any way round this been told it was just th gm1920 which wouldn't be able to use this way of updating I'm with E.E locked on Ee it was purchased from ee my fone is running excellent,just want the choice of updating.thansk
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
08-03-2021 02:09 AM
Posted in the open:
@Babayaga781 wrote:
Hi,I have a OnePlus 7pro 5g EU gm1920 currently using android 10.o.s 10.0.10 this is stable build running perfectly,I'm on sim only but phone is on Ee it's not allowing me to local update the android 11 beta can u confirm if this model is compatible or not,as I've been told it's not without any explanation just maybe cause it's limited model could you help please thanks hope gave enough information.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
08-03-2021 10:31 AM
Hi @Babayaga781,
I'd recommend contacting the manufacturer for help with any queries about using their Beta software builds.
