close
imlRe: Laptop will not connect to 4G EE WIFI MINI
suffolk99
I have a similar problem which eventually sorts it self out.
But my problem is connecting to HSBC online banking. Every time i try it drops out saying network change detected.
What is this issue ?
I can log on to other banks with no problems.
When the connection is eventually made from my laptop to the 4g mini dongle,i get a warning message from windows saying that the device security is out of date !
I have only had the thing for 6 weeks so is this correct ??
Help !!!!
Hi again !
Thank you for the info,i changed the auto to aes and it now connects to hsbc bank website.
Cheers again !
9 REPLIES 9
@suffolk99 : What lappy is this? What mobile router is this?
An Alfa 600c by Hometech.
4g ee mini wifi dongle
Login to your MBB router at http://192.168.1.1 with username/pwd as "admin"/"admin" or with the password found under the battery cover. Then on the WiFi Settings tab try changing the WiFi to:
Security = WPA2 PSK
if it's not already, as it should be.
hi, thanks for the infoI but I cannot see any where to enter 2 sets of
password,only one and admin is not it.
any more help is really appreciated !!!
What 2 sets of pwds? I gave you alternatives. Have you looked under the battery cover?
Yes,found it thanks.
The wpa setting does not allow a psk option only wpa2 or wpa/wpa2.
So where do i go from here please ?
Hi again !
Cheers again !
Thanks! You're welcome 🙂 ! Glad I could be of assistance & it is now sorted.
my neighbour who is a techie type says that maybe HSBC wrap a security shield around the log in software and when there is a slight change in signal strength or a change of base station it locks you out.
