on 22-02-2021 09:12 AM
I am about to upgrade from a 11 Max to 12 Max, I have 2 numbers on dual sims, will they automatically transfer to the 12 Max or do I need to have them transferred by EE, Just to clarify does the e-sim transfer?
on 22-02-2021 11:19 AM
Hi @Philzyg,
Is the number you are upgrading on the physical SIM or eSIM?
Is your other number on a SIM only plan?
on 22-02-2021 01:07 PM
I have two numbers one on e-sim and the other on a physical sim, I want both to be moved to my new phone. Do they transfer both to the new phone automatically?
on 22-02-2021 01:46 PM
Hi @Philzyg,
Which number are you upgrading? The number on the eSIM or the physical SIM?
